VATS Question
Old Jun 15, 2008 | 10:10 AM
88TransAmFreak's Avatar
Car: 1971 Camaro
VATS Question
What is the easiest and cheapest recourse for someone to get a key made for a car that has VATS, but no key or a way of knowing what resistance the module needs to start the car?
I'm not concerned with the VATS system, and have seen things on ebay that can plug in to eliminate it.......but you still have to know the resistance of the resistor.
Is there a way to test the module?
Old Jun 17, 2008 | 11:38 PM
Pop45398's Avatar
Car: '91 RS
Engine: 355 on a stand
Axle/Gears: 3:42
Re: VATS Question
Take the title to any GM dealer and they will fix you up--and charge you accordingly--used to be $21 several years ago. You used to just have to give them the VIN# but it was too easy for thieves to do that.
If you don't care about having VATS, use the search function here as there is plenty of info n disabling it, and you can visit http://vatssucks.com.
Old Jun 18, 2008 | 05:48 AM
Car: 1971 Camaro
Re: VATS Question
Thanks for the help.....no title It was a harness (1989 Firebird) I bought from the junkyard.
I just bought another harness (1988 Firebird) from a forum member and resolved this issue
Old Jul 10, 2008 | 07:49 PM
one2burn's Avatar
Re: VATS Question
Hi can you help me with the ebay locations for the vat eliminators, thanks george.
stalkier
Dec 6, 2015 11:25 PM
WIzmo
Aug 30, 2015 02:30 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
stalkier
Aug 13, 2015 12:59 PM
