keyless entry: how to add flasher function
Old Jun 16, 2008 | 04:05 PM
swisscheese's Avatar
Car: '91 Z28
Engine: LB9
I just added a keyless entry system. Now I want to add the park-/taillamp flash function. I'm not sure witch wires I have to connect. Anyone can help me with this one. Eventually with pics?
Old Jun 16, 2008 | 04:50 PM
Pop45398's Avatar
Car: '91 RS
Engine: 355 on a stand
Axle/Gears: 3:42
Re: keyless entry: how to add flasher function
You'll want to connect the output of your relay (the one you connect to your keyless entry system as per its instructions) to the brown wire at terminal E of the light switch. You can also access this wire at terminal B1 on connector C100, the big connector with (up to) 42 wires that goes thru the firewall on the driver's side. Looking from the interior, terminal B1 will be the second row from the top, first on the right.
InfernalVortex
Apr 20, 2021 11:31 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
gord327
Oct 3, 2015 01:25 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
