Pop-up lights have their own mind!!!!!
Car: 1986 Trans-Am
Engine: 305 4 bbl
Transmission: 700R4 auto
Axle/Gears: posi
I was wondering if anybody has had a similar situation, and could help me out? I have an 86 trans-am. I've owned the car since it was new, and never had a problem whatsoever with the pop-up lights. The other day I turned on the switch, and nothing happened. I did this several times and they finally popped up. When they do pop up, they will go up and down as many times as you flip the switch. If you come back maybe 30 min. later, it might take several times working the switch before they start working again. Any suggestions will definately be appreciated! Thanks.
