battery,starter,or??????
Old Jul 7, 2008 | 05:08 PM
dwright69's Avatar
I got in the car today and all dash lights worked including the dome light, I turned the key to start the car and it made a "click" sound and that was that!! No start or even a part of a crank...NOTHING!! The car actually WENT STONE COLD DEAD!!!!!!! the dome light and everything was just dead. I had the battery teated and they said it was gone. So I just replaced the battery , That did no good. Could it be the starter...or ??? Has anyone experienced this before?
Old Jul 7, 2008 | 05:21 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: battery,starter,or??????
Could be the battery cables. I've seen them oxidize inside out. Especially if you have aftermarket cables.
You can get down under the car and test the voltage on the starter posts. If you see 12V on the main post with all the wires, it's not your battery and it might be the fusible links. Try playing with them and see if it corrects the problem. In which case you'd need to replace them.
You can also follow the power to the fuse box. If you have power on the starter but not in the fusebox, it's likely the fusible links.
Hope this helps.
Lou
Falcon50
Aug 22, 2020 03:26 PM
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
drumstixer
Sep 29, 2015 03:02 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
