My new led gauges, complete with annoying seat belt chime...help!!
Old Jul 11, 2008 | 03:14 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Ok so i got my blue led dash installed looks great but now for no apparent reason my seat belt chime just goes off constantly, i checked my doors, lights, seat belts, everything and theres no reason for it to be going off, so i obviously screwed something up, my question is when i was doing my dash one of my gauge lights was missing, so i pulled the bulb out of the seatbelts light socket and just used it elsewhere, is that my problem?? Is the constant chime a fail safe in case the bulb burnt out? do i need to go get a new bulb or is there a way i can disable the chime? Im pretty good with the whole seatbelts and lights thing so i dont need a reminder ( been in one too many horrible accidents that the seatbelt saved me)
any help would be greatly appreciated
Old Jul 12, 2008 | 02:36 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: My new led gauges, complete with annoying seat belt chime...help!!
BUMP! Somebody help me out here please
Old Jul 13, 2008 | 02:28 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
anyone??
Old Jul 15, 2008 | 03:16 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
cut the yellow wire in the convenience center. That should kill your seat belt fasten light along with the chime associated with the light... more here
Old Jul 15, 2008 | 10:35 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
You can disable the chime by disconnecting the connector housed in the driver side seat belt reel on the door sill. All this does is supply a ground to the indicator and chime when there is no tension on the seat belt. I would much rather disconnect a ground than 12 volts.
Old Jul 16, 2008 | 03:47 AM
HCR13's Avatar
Car: 1987 Trans Am
That didn't work for me for some reason. Thats the only reason I had to seek how to remove the 12v. Good luck...
Old Jul 17, 2008 | 02:22 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
well my seatbelt chime didnt really ever chime for the belts, just the lights so i didnt even try hunting down that mess lol
For curiosities sake i moved the upshift light over to the fasten seatbelts slot and it worked, so there has to be a bulb in the socket or the chime just goes off
Just to kill the issue for good i took out the module and opened it up pulling out the metal disk that produces the chime and reassembled it then put it back, no chime, no more inaccurate upshift light, and a killer set of gauges i think ive made out on top lol
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
MORREALE5
Sep 13, 2015 09:16 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
scottmoyer
Aug 9, 2015 10:18 PM
