Wire Harness to stock ECU
Old Jul 11, 2008 | 07:35 PM
HonkyTonkMan's Avatar
What is this harness for ?
There is 2 plugs in the end of it and they connect to the stock ECU from the fusebox..
I'm Guessing i need to keep some or all of the wires.. but i'm just wondering what they did, so if anyone has a simple answer so thanks.. (I'm installing Commander 950, so i would like to get rid of as much of the stock wires as i possibly can)
I'm sorry about the arrows that i drew on the pic, they are kind of hard to see!
Old Jul 12, 2008 | 07:07 PM
Re: Wire Harness to stock ECU
Dont anyone know what this is good for ?
Or have an url to some block schematics for te 3'rd gen TPI camaro ?
plz help.. .
tnx..
Old Jul 21, 2008 | 01:42 PM
plz help.. .
tnx..
They dont connect to the ECU, but maybe to the ecu Harness ? to the engine bay ?
Dont anyone know ?
Old Aug 1, 2008 | 05:27 PM
As i investigated this problem some more, i found out that they dont connect to the ECU... they plug in to the stock engine harness it seems..
BUT WHAT ARE THEY GOOD FOR ? DOESENT ANYONE KNOW ?
Old Aug 2, 2008 | 08:18 AM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Transmission: gto t56 (mn12)
That connector is one of the lifelines for your car. You can't remove it without major modifications. It is labeled connector 207 in the diagrams. It routes voltage to the computer, it sends information from the computer to sensors such as vehicle speed, it is connected to the park/neutral switch or clutch switch, sends power to the distributor. There are 15 pin outs to that connector. Do you want me to keep going? Point is you need that connector to stay where it is. Hope that helps.
Old Aug 2, 2008 | 12:33 PM
The Engine harness is completely removed, the only thing i really need left in the car is power to the dist, and , hmm, yea thats about it...
the engine harness is completely removed, new harness and commander 950 system...
the gauge cluster is also completely removed and will be replaced with a dakota digital unit. and so on ..
Old Aug 2, 2008 | 04:07 PM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
So do you want the pinout of every single slot on that connector? That way you know if there is anything you should keep.
Old Aug 2, 2008 | 07:56 PM
YES! thats exacly what i want!
but there is 3 connectors there...
and i cant find these on the wiring diagrams that i have! do you know where i could find such a thing ?
Old Aug 2, 2008 | 08:04 PM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
You have to get a full service manual for all the intricate wiring diagrams. Do a search on this site and you may find what you need.
http://www.geocities.com/vtcamaro/Wire-Diagrams.html
http://www.austinthirdgen.org/index.php?pid=19
Try those sites and see if you get what you need.
eightsixseven
Dec 16, 2024 01:50 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Caspar
Jun 19, 2016 11:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
