INFL REST Lamp issue
Old Jul 10, 2008 | 09:13 PM
blue91z28cam's Avatar
Car: 1991 Camaro Z28
Engine: 305 LB9 5.0L
Axle/Gears: POSI 2.73
Re: What Does INFL REST mean?
sorry to bring it up from the dead but I searched around and still dont understand my problem......My INFL REST light stays on all the time..its been like that for a couple years...I have a new Steering wheel and bag would that fix it or is there something else to it....
I also have a Chilton's manual, should the solution or info about it be in that book
Thanks in advance guys
Old Jul 10, 2008 | 10:00 PM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Transmission: Tee five six
Axle/Gears: 10 Bolt 4:10's
Inflated restraint. (Airbag)
Old Jul 10, 2008 | 10:18 PM
yea I know that man, but what my question is and sorry for not making my question clear: why does my light stay on, is it normal?
Old Jul 10, 2008 | 11:49 PM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
It should go off after you start the car. If it doesnt maybe you have a wiring problem? Usually if it stays on it means your airbag isnt working
Old Jul 11, 2008 | 03:33 AM
Jix01's Avatar
Car: 1990 Pontiac Firebird
Engine: 305 5.0 TBI
Axle/Gears: 2.73 Open Diff.
my light comes on all the time while im driving too and blinks every once in awhile. i was just gonna probably remove the steering wheel and put an 86 or 87 3 spoke firebird wheel on there.unless someones knows what the problem might be lol.
Old Jul 11, 2008 | 02:31 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Your airbag sensors are f*cked.
Old Jul 11, 2008 | 02:46 PM
So replacing them would solve the problem?
And if they are f'd up would that mean that the bag can explode whenever it wants to, or will it not inflate at all?
I turned on the car this morning and notice that it does blink 7x's but it still stays on afterwards
Old Jul 12, 2008 | 07:18 AM
rkjjeep's Avatar
Car: 92 Red RS With 18K Miles
Engine: 305 TBI
The system goes thru diagnostics and if it seems something wrong it lights the light. I haven't worked on these in a while. There is a way to plug in and rtetrieve the stored codes - if the light stays lit there should be stored codes to point to the problem.
Old Jul 13, 2008 | 04:24 PM
JT's Avatar
JT
Community Administrator
No. Replacing parts without proper diagnostics leads to money and time spent that may not resolve the issue. There are about 18 trouble codes that could be produced. The INFL REST lamp being on is much like the Service Engine Soon light being on. It could be on for one or more different reasons. There are sensors and wiring involved.
You can read the current codes by grounding terminal K of the ALDL connector while the ignition switch is ON. This will result in the system going into "Flash Code" mode and flashing the INFL REST lamp, which you will have to decode to produce the proper trouble code.
This is how GM describes reading the INFL REST lamp once in "Flash Code" mode:
Each code displayed consists of a number of flashes which represents the tens or first digit, a 1/2 second pause, then a number of flashes which represent the ones or second digit of the code. Each code is flashed once before moving on to the next code. After all codes have been displayed, the entire code sequence will be repeated until ground is removed from terminal K of the ALDL connector.
In addition:
Two special codes exist when reading in the "Flash Code" mode, Code 12 and Code 13. Code 12 will always be the first code displayed when the "Flash Code" mode is enabled. Code 12 is not an indication of a SIR fault, but an indication that the "Flash Code" mode has been enabled. If there are no current or history codes present the DERM will continue to flash Code 12 until ground is removed from the ALDL connector at terminal K. Code 13 will be displayed if there are history codes. To read the history codes, use of a Tech 1 is required.
If you can figure out the code, we may be able to help point you in the proper direction.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
TheTraut88
Sep 11, 2015 05:16 AM
FormulasOnly
Sep 6, 2015 10:42 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
