Mechanical to Electronic speedo swap
Old Jul 13, 2008 | 11:55 PM
J_Dubb44's Avatar
Car: 1984 Pontiac Trans Am
I have an 84 Trans am which has a gauge cluster with a mechanical speedometer. I have another gauge cluster from an 85-90 Trans am that has an electronic speedometer that i want to swap into mine. Is there anyway i can do this? And if so how do i go about doing it and what will i need to buy?
Old Jul 14, 2008 | 12:48 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Mechanical to Electronic speedo swap
It might be more trouble than its worth. You will need an 86-89 2000 pulse per mile electronic speedo sensor for your 700R4. That will need to get wired to both your speedometer in the dash, AND the correct spot in your computer so it knows how fast you are going. That's all I know.
Old Jul 17, 2008 | 10:23 AM
kwp289's Avatar
Car: 87 Trans Am
Engine: V8 305 TPI
Yeah I wouldn't do it, the gauge cluster I think looks a lot better than the electronic one anyway. But its a lot of unscrewing to get down to the cluster, then you have to worry about all that wiring, take it to a mechanic.
Jorlain
Aug 24, 2022 05:11 PM
gta90
Sep 15, 2015 04:00 PM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
87 camaro iroc
Aug 20, 2015 07:47 AM
