Gauge or Sending Unit?
Old Jul 17, 2008 | 11:15 AM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Ok guys how can you tell if your Fuel sending unit is bad or just your gas gauge? My gauge reads FULL and i was wondering if the sending unit IS bad would the gauge be reading full or empty?
Old Jul 17, 2008 | 11:33 AM
kwp289's Avatar
Car: 87 Trans Am
Engine: V8 305 TPI
Re: Gauge or Sending Unit?
I had the same problem...is there a ringing in the back of the car, could be the fuel pump going bad, happened to me, so I replaced it and now everything works. When your gas gauge doesnt work most people would assume it is your sending unit, which would be a little expensive being that you gotta drop the fuel tank. It could also just be your fuel sensors. I would start at the cluster to make sure everything is plugged in.
Old Jul 17, 2008 | 12:35 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Find the fuel gauge wire and ground it (with the key on). If the gauge drops to Empty, it'd appear to be working and you might have a broken/disconnected wire anywhere between the instrument cluster and the gastank.
If you have access to some resistors, you can disconnect the wire at the fuel tank (connector C313 - look it up) and test the gauge by putting different resistances on the fuel sender wire (against ground). Test a few resistance values, from 90 Ohms for full tank down to almost 0 Ohms for empty tank.
Hope this helps.
Lou
Old Jul 19, 2008 | 03:39 AM
kcb37's Avatar
It should drop to empty disconnected, and peg full when grounded.
Old Jul 19, 2008 | 09:47 AM
BigBadLou's Avatar
Engine: TPI
Please do not spread misinformation, it does not help anybody.
The fuel gauge goes to full when disconnected and then to empty when grounded.
Hope this helps.
Lou
toyotekk
Sep 7, 2015 06:36 PM
Glowsock
Sep 6, 2015 06:40 AM
Glowsock
Sep 5, 2015 07:48 PM
rsrookie
Sep 5, 2015 07:08 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
