Electrical Problem, Please help!!
Old Jul 17, 2008 | 10:42 PM
90-Vert's Avatar
Car: Looking
I have a 1990 iroc convertible and I went for a drive tonight and the dash lights went out and the driving lights. When I replace the fuse for (20 stop lamp) it blows imediately when I turn on the lights. Also I have no parking lights? Anyone know what or where to look? Everything works except the parking lights, dash lights and fog lamps? I do have head lights and brakelights? Could this be a stereo issue? I have an aftermarket stereo with amps and subs, but all of that is still working?
(There is a wire that controls the brightness of the radio, could it be touching metal and causing this?) After all this is aftermarket equipment. I just got the car and might have answered my own question. Please add comments if you have seen this before.
Old Jul 17, 2008 | 11:04 PM
90-Vert's Avatar
Car: Looking
Re: Electrical Problem, Please help!!
Ok update, it is not in the stereo. Just pulled it and no problems.
Old Jul 19, 2008 | 10:00 AM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
sounds like the switch is going bad 20 for a new switch should be good.
Old Jul 19, 2008 | 10:05 AM
90-Vert's Avatar
Car: Looking
I thought so also, new switch installed and still blowing fuses! The car is at a shop getting the non-working alarm removed and then go from there? I traced everything and found nothing?
Old Jul 19, 2008 | 01:19 PM
enswrob's Avatar
Car: 89 Firebird
Axle/Gears: ?
gotta check the grounds on that circut.. could be a loose one causeing it to short and blowing the fuse
Old Jul 19, 2008 | 05:09 PM
90-Vert's Avatar
Car: Looking
Found the problem!! It was a corroded light socket. The left front turn signal socket was corroded and shorting out. Cleaned it and voala. fixed.
toones
Jan 6, 2016 06:00 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
