hatch motor stuck up
Old Jul 19, 2008 | 08:05 PM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
i replaced the motor, gear and housing for the hatch motor a few months ago and today it got stuck in the up position. it stopped workin without warning.
all fuses are good.
autozone had the relay in stock so i went ahead and replaced it..no luck
plz help...this is my dd!
Old Jul 19, 2008 | 09:13 PM
Fyrstorm's Avatar
Car: 86 Trans Am
Engine: 385 Fast Burn
Transmission: 700R4 - stock (eep!)
Axle/Gears: Stock, will upgrade at some point
Re: hatch motor stuck up
[1] Does it have power? Mine stopped working suddenly, somehow no more power to it. I've temporarily jumped some power from the lights just to get it closed. I had the whole thing out of mine and I didn't even think to check the power first. Yes, I did check the fuses first
[2] Switch that detects if the latch has entered the slot may be worn out. First I checked for continuity. Then, and this is completely up to you and this as a last resort , I drilled out the plastic "rivets" had a look inside and everything was fine. Be careful taking it apart, there's a spring in there for the switch and 2 small pieces of metal with prongs that slide with the switch. They'll pop out on you. I cleaned it up, put new lube into it and put it back together with some small nuts and bolts I had lying around.
Failing that, you can take the motor out and see if it actually runs. I used my battery charger juryrigged up to my multimeter wires and just touched them quickly to the plug on the motor to see if it would raise and lower.
How are the guides? Did you lube them up really good if you had it out already? I couldn't believe how tight mine was when I cleaned and re-lubed the channels. I used a ton of grease to get everything moving freely, lots of catching the overflow on a rag too hehe.
Just some ideas, and I hope some of the things I did just last month help you out.
Old Jul 19, 2008 | 09:39 PM
Car: 1986 IROC-Z28
thanx for the help...i'll have to look at it in the morning
Old Jul 19, 2008 | 09:48 PM
Car: 1986 IROC-Z28
how do i jump power to get it closed
Old Jul 20, 2008 | 07:51 AM
Car: 1986 IROC-Z28
turns outthe retainer clip that holds the switch to the motor broke so the switch was hanging loose.
Old Jul 20, 2008 | 09:18 AM
Fyrstorm's Avatar
Car: 86 Trans Am
Huzzah! Glad it was an easy fix, these things can be a pain in the butt.
zayne0
Aug 24, 2015 07:22 PM
neekolzun
Aug 24, 2015 04:59 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
1nastygta
Aug 8, 2015 07:38 PM
