Electrical Guru's step inside simple question
Old Jul 25, 2008 | 10:37 PM
IroczInOz's Avatar
I am kind of looking for a possible electrical problem that may be interfering with my fuel pump and thus effecting fuel pressure.
I have done the following can someone confirm if this is normal.
I am using a multimeter and set it to buzzer
1. With doors closed and no lights on etc.. If I check my grounds I get a reading of around .01 to .05 ohm. This is on every single ground I can find under the hood.
2.With door left open so interior light is on I do the same test and now the readings are around 35ohm on all grounds except for the main battery from negative to alternator cable. There it is around 1ohm.
3. With headlights ON I do the same test and now the readings are over 100ohm on grounds.
So my question is this normal behavior?
Old Jul 25, 2008 | 10:44 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Electrical Guru's step inside simple question
Resistance measurements on a powered circuit are meaningless.
Old Jul 25, 2008 | 10:45 PM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
i think he means you are wasting your time.
Old Jul 25, 2008 | 10:59 PM
IroczInOz's Avatar
Okay so basically if the ground is all good with no circuit running and everything off then all is good.
One of the reasons I asked is every time I turn on headlights my fuel pressure drops by 3-4psi according to my digital gauge inside the car.
Old Jul 25, 2008 | 11:02 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Check your pressure with a real gauge.
Old Jul 25, 2008 | 11:09 PM
IroczInOz's Avatar
So these Dakota digital gauges are not the real thing?
Old Jul 25, 2008 | 11:11 PM
Car: Camaro RS
im not an electrician but it sounds like your fuel pressure guage is run by electricity and when your lights turn on it takes voltage away. hence dropping unless it stays down then i dont know.
Old Jul 25, 2008 | 11:15 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Well I'm sure they're pretty. Before you start worrying about something as insignificant as 3-4 PSI, make sure you're seeing something real.
Old Jul 25, 2008 | 11:16 PM
Car: Camaro RS
well if it makes anyone feel any better mine goes from 60 to 0 whenever it feels neccesary other wise its at 30
Old Jul 25, 2008 | 11:21 PM
IroczInOz's Avatar
Well at the moment 3-4psi is a lot for me when I am down already 6-8 from normal.
I'll get a hand held gauge to check it out. I would be shocked if the gauge is the problem.
MustangBeater20
Oct 29, 2022 09:20 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
camaroken83
Aug 10, 2015 11:35 AM
