Headlight dimmer switch meltdown?
Old Jul 29, 2008 | 08:42 PM
Alminate's Avatar
Car: 85 Camaro
Axle/Gears: 3.42 posi
This is what I discovered when I pulled my dimmer switch - due to cluster lights not working. (see attached)
2 of the pins melted/broke off the switch & are now one with the connector.
I'll be picking up a new switch & either get a connector from a junk yard or do something with spades.
Anyone ever seen this happen before & what could have caused this?
Attached Thumbnails Headlight dimmer switch meltdown?-meltdown1.jpg   Headlight dimmer switch meltdown?-meltdown2.jpg
Old Jul 29, 2008 | 10:16 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: Headlight dimmer switch meltdown?
I Have seen this before but not on a third gen. What Type of Headlights do you have? If you use HID's and not use a relay, it will burn up your switch.
Hope this Helps.
Old Jul 31, 2008 | 12:08 PM
Alminate's Avatar
Car: 85 Camaro
they are stock headlights.
I finished replacing the switch & the cluster lights still don't work!
I pulled the gray wire from the fuse block and ran a hotwire to it, still no cluster lights.
What should I check next? Where are they grounded?
Old Jul 31, 2008 | 02:57 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
start with fuses. It might have been a short. Did you smell/see any smoke when this happened?
Anything else damaged that you can see?
Old Jul 31, 2008 | 03:54 PM
Alminate's Avatar
Car: 85 Camaro
Re: Headlight dimmer switch meltdown? Now no cluster lights!
I discovered that the previous owner had a 20 amp fuse in the spot for interior lighting, WHERE THE 5 SHOULD BE!
So that explains the meltdown, but I dont know where to look next to get the cluster lights working.
I didn't notice any smoke, I just noticed that my cluster lights would no longer come on. There is nothing else damage that I can see.
Does anybody know where the cluster lights are grounded?
Old Jul 31, 2008 | 05:10 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
does your car have any other accessories (other than stock stuff) or a hack job wiring?
It may be that he was running more than one thing for that fuse, and put in a 20A fuse. While youre at it, did you notice any other highly rated fuses in other banks?
I would imagine if it melted the switch, it would have also done a number on the wires.
I dont think this is gonna be a quick fix......
DO you have a new switch? How do you know they still arent working?
Old Jul 31, 2008 | 05:55 PM
Alminate's Avatar
Car: 85 Camaro
[quote=Alminate;3841775]
quote]
The last owner did a hack job, but Im not going to deal with it (right now anyway).
I'm just going to run another switch for now so I can drive the car at night and know my speed.
Old Jul 31, 2008 | 08:54 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
If the last owner did a hack job, all bets are off. You may want to invest in a shop manual (check ebay). They basically tell you how to take the car apart and build it all over again.
In the mean time, give your fuses a quick run through, but more importantly, you need to install a couple of fusible links. youre lucky the switch melted, and you didnt have a fire.
So do what you need to do to make the lights work. A DVM or even a test light is your freind, and you will just have to trace wires till u find what u need.
I would install a fusible link (say 30-35 amps) on the main wire that comes out of the alternator. That way if you have a short, that fuse will save the rest of your wiring and possibly a fire.
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
Randomtask2
Sep 10, 2015 08:37 AM
sylentnite
Sep 9, 2015 02:55 PM
luvofjah
Sep 3, 2015 07:08 PM
