alternator spikes, then shuts down.
Old Jul 30, 2008 | 02:05 PM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
Transmission: 700-R4
Axle/Gears: Moser 9" with 4.11
i did a search btw...
Ive noticed my voltage would shoot up to 15-16 (almost in the red) then would spike and drop to 12. The battery would slowly lose charge after that and eventually kill around 8 volts. i put a new alternator in and the volts would stay around 15. Now its doing the same thing.
I checked the conector (looks okay)
i am using a pigtail with 3 wires blk, red, brwn,... there is only a red/brown wires going into the car harness.The black wire on the conector is just cut off and the pigtail is spliced into the car harness. This was the way i bought the car and it has worked fine. this is only my second alt. in 11 years. Im also running the battery in the trunk.
Old Jul 30, 2008 | 02:06 PM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
Re: alternator spikes, then shuts down.
Your brushes in the alternator are bad. Or your internal regulator is shot.
Or both.
Old Jul 30, 2008 | 02:20 PM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
i just put in a new (remanufactured) alt. what do the wires that plug into the alternator (pigtail connector), actually tell it to do? can i hook a meter to the wires coming out of the car harness to trouble shoot?
Old Jul 30, 2008 | 03:58 PM
Car: 1992 RS 6spd
Damn that wiring diagram is obnoxious. Copy and paste it into a bitmap for a much better view of it. Look for generator on diagram, shows where all wires in stock configuration go.
Last edited by calamitascamaro; Jul 30, 2008 at 04:01 PM. Reason: Automerged Doublepost
Old Jul 31, 2008 | 12:52 AM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
thanks, i will check this out and report results..
Old Aug 1, 2008 | 02:28 PM
Car: 1992 RS 6spd
Any luck?
Linson
Oct 24, 2025 02:00 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
Linson
Oct 1, 2015 09:50 PM
ironbmt
Sep 27, 2015 06:00 AM
