Please help I am at a complete loss!
Old Aug 4, 2008 | 07:20 AM
Kryppy's Avatar
Car: 87 Camaro
Engine: V-6 MPFI 2.8 liter
Transmission: 700 R4
First of all let me thank you for taking the time to read this. Okay it started out every once in a while after shutting it off it would not start back up. When I would turn the key to ACC I could hear the fuel priming up. As soon as I would turn the key all the way to start it would go completely silent, not a click nor whir & it would even interupt the fuel priming. One thing I noticed that I thought was kind of odd was that when the key was on ACC all the dummy guages would light up except for the water temp. onen. That one lights up when I turn the key to start. I have replaced just about everything electronic to try to resolve this issue: dist. cap & rotor, coil, ignition switch, starter, even the computer. Is it possible since the water temp light does not go on with all the others when the key is on ACC that maybe the water temp. sensor is the culprit? I am thinking (& hoping that is the case) or I'm thinking it's the prom. Cause that's the only thing left I haven't replaced I'm pretty sure. Any advice would be greatly appreciated. Thank you.
Old Aug 4, 2008 | 07:23 PM
1970 Buick's Avatar
Car: 1989 GTA
Re: Please help I am at a complete loss!
Have you checked your VATS system? Does the security light come on?
Old Aug 4, 2008 | 11:17 PM
Kryppy's Avatar
Car: 87 Camaro
Thanx for your response but I do not have VATS.
wigmobile
Feb 26, 2025 02:56 PM
MM2Robinson
Oct 1, 2017 09:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
MORREALE5
Sep 13, 2015 09:01 PM
