o2 sensor wire problem?
Old Aug 4, 2008 | 12:06 PM
MarkimusPrime's Avatar
It appears that the wire for my o2 sensor has been torn in half...just I can't find where the other half goes. I've never seen it in good condition...ahaha.
Where might the other half of the wire be leading to? Pictures would help also if you can get one. Thank you so much.
Old Aug 5, 2008 | 07:51 PM
Re: o2 sensor wire problem?
Figured out the location myself. The wire was hanging down under the car...right by the crossmember. All connected back up...runs MUCH better than it did before.
Old Aug 6, 2008 | 09:40 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
You did change to O2 Sensor as well right?
After they short out they never seem to read correctly again.
Old Aug 15, 2008 | 04:29 PM
No, I did not replace the o2 sensor. It didn't short out, I think I broke it when I was working...not really sure.
I will change it, but right now I'm broke just tryin to get it workin as nicely as possible.
eightsixseven
Dec 16, 2024 01:50 PM
Infested
May 22, 2018 11:56 PM
Caspar
Jun 19, 2016 11:19 PM
