distributor cap melted
Old Aug 19, 2008 | 11:47 PM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
Transmission: Megaraptor
sorry if this is in the wrong forum, mods please move as you see fit....
i have a mallory unilite distributor, mallory promaster coil, msd 6a box hooked up with blue moroso wires to NGK R5672a-9 spark plugs.
heres the problem, the carbon tip inside the cap melted causing misfiring and the such.
i have 4 cylinders not working (plugs fouled)
what could have caused the carbon tip to melt like that. could that have caused the plugs to foul, or the other way around?????
this is the second time this has happened (it happen a while back with my other engine) im using the balaster mallory recommends
im also using the plugs that AFR recommends starting out with.
i have about 10.8:1 compression on stroked out 350
any ideas.........
Old Aug 20, 2008 | 03:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: distributor cap melted
http://store.summitracing.com/partde...=&autoview=sku
Old Aug 20, 2008 | 04:50 PM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
even w/ the Mallory distributor........
you would think they would have that on their caps, no?
Old Aug 20, 2008 | 05:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Maybe, maybe not. Should be easy enough to tell by looking at it.
MM2Robinson
Oct 1, 2017 09:16 AM
camarohelp
Sep 22, 2015 03:19 PM
BLK87Z
Sep 18, 2015 11:29 PM
m00n420
Sep 11, 2015 02:39 PM
Jlanz55
Sep 6, 2015 03:05 PM
