Fuses keep blowing, cd player wont work.
Old Sep 4, 2008 | 07:50 PM
tweakhat's Avatar
Car: 1986 Trans AM
Engine: LS1/T56
Axle/Gears: 3.83
my car keeps blowing a fuse right when you put it in, the dome light, power door locks and cd player wont come on, and automatic rear hatch lock, it worked before i got a guy to install my engine, can anyone tell me where this short may be or how i can fix this? all my fuses work except 1 it blows right when you put it in, even with the key turne off. thanks alot
Old Sep 4, 2008 | 09:57 PM
CamaroRider's Avatar
Re: Fuses keep blowing, cd player wont work.
Can you try to unplug your CD player from the power source (to isolate it) and see if a new fuse still blows? If the fuse does NOT blow then the problem would be with the CD player. And if the CD player is the problem then check to make sure the serial number of the CD player is the same as the one you originally purchased.
Old Sep 8, 2008 | 01:47 AM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
I had this same problem and it turned out my cigarette lighter was bad and blowing all the fuses I put in that socket. CD player, dome light and a few other things I can't remember would all go poof.
I had to replace the entire assembly and then that fixed it. It also gave me the ability to use more modern/custom lighters and accessories since I didnt have that funky 80's style socket too.
Try removing the lighter from the socket and see if it still blows. Your mileage may vary...
3rd gen money
Oct 11, 2019 09:57 PM
jrdturbo
Mar 31, 2016 02:58 PM
thunder57
Nov 7, 2015 02:28 PM
Fanatic1074
Oct 2, 2015 03:47 PM
Linson
Oct 1, 2015 09:50 PM
