swapped to a older 355 motor and need some help with wiring
Old Sep 7, 2008 | 01:32 PM
GMZombie's Avatar
Car: 89 Camaro RS Convertible
Engine: 355 chevy power
Transmission: 5 speed manual
Axle/Gears: standard
just as the sub says i got the car working and whatnot, but it dosent have the oil pressure/sender switch hole above the oil filter. so i was going to use a standard oil pressure sensor like most would be i have that weird plug that plugged into the switch and i dont know which one goes to the gauge. i tried to put a bare wire that is hooked to the oil pressure sensor on the top, into all three holes with no luck and i heard this also has something to do with the fuel pump also?
Old Sep 7, 2008 | 08:56 PM
kerplunk318's Avatar
Re: swapped to a older 355 motor and need some help with wiring
one wire goes to the gauge, the other comes from a switched 12 volt source (ignition) and the third goes to the fuel pump (fuel pump is only on for a few seconds when key is turned and then stays on if there is oil pressure)
midge54
Sep 2, 2020 07:13 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
st.evel07
Aug 13, 2015 06:15 PM
92projectcamaro
Aug 6, 2015 01:20 PM
