Power Antenna
Old Sep 11, 2008 | 08:43 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
Power Antenna
I did a search and didn't come up with what I need. I got a power antenna from a GTA at a swapmeet. My car didn't come with one, so I'm going to need to wire it in. Anybody have a schematic for the wires that plug into the antenna?
Side note: Anybody know where to get the wire terminals that have the tab on the back that you push out and it will lock in a plug? Like this:
I have no idea where to buy them!
Old Sep 12, 2008 | 10:13 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
ANTENNA . . . . . UP!!!!!
Most manufacturers use black, red, and green for color coding.
Connect the black to chassis or negative on the battery.
Connect the red to a switched positive line.
Connect the green to the radio’s automatic antenna terminal.
If the radio doesn’t have that feature install a switch.
(one side of the switch to the green and the other side to a switched positive line)
You can obtain terminals for the one in your picture at auto parts stores or RadioShack
Happy Racing!
-If people drove any slower
they’d be going backwards-
Old Sep 12, 2008 | 10:17 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: Power Antenna
The antenna trigger is from the radio harness (pink wire) and the main feed is from the fuse panel. I've included a wiring diagram I hope is of help and the web link to it.
http://www.gmtips.com/3rd-degree/dox...ntenna/ant.htm
Old Sep 12, 2008 | 11:35 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Re: Power Antenna
Thanks, that will help alot.
Now if only I could find those connectors!
Old Sep 13, 2008 | 01:33 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Power Antenna
Check here for the terminals you're looking for.
http://www.eagleday.com/blco.html
83 Crossfire TA
Jan 3, 2016 01:26 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
sailtexas186548
Aug 24, 2015 10:11 PM
