Stock Tach Question?
Old Sep 15, 2008 | 07:08 PM
V8hareed's Avatar
Car: 1991 Camaro RS
Engine: 350 ci
Axle/Gears: stock?
So I have a quick question that I couldn't seem to find the answer to...
I'm running a stock tach, but where do I hook it up??
I just recently did an engine build, and I've read that hooking up the white (negative) coil wire from the stock harness to your current coil negative is how it's supposed to be hooked up, but my tach is all over the place! Correct me if I'm wrong, or maybe it's just a poor connection?
Thanks guys.
Old Sep 15, 2008 | 08:18 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Stock Tach Question?
Connect it to the tach terminal on the distributor.
Old Sep 17, 2008 | 12:09 PM
V8hareed's Avatar
Car: 1991 Camaro RS
Engine: 350 ci
Axle/Gears: stock?
Which terminal is that? I'm running a HEI distributor with MSD 6a ignition.
Old Sep 17, 2008 | 01:16 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
There should be a tach input on your MSD box.
Mine does, although I've got my soft touch rev
box plugged in there.
HTH
Later
Old Sep 17, 2008 | 01:24 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you have an MSD you need to plug it into the tach terminal on the MSD box.
Old Sep 21, 2008 | 12:35 PM
V8hareed's Avatar
Car: 1991 Camaro RS
Engine: 350 ci
Axle/Gears: stock?
Is there some kind of adapter you can buy that plugs into that weird terminal?
Old Sep 21, 2008 | 04:33 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
What weird terminal? It's a standard .250" flag connector.
Old Sep 23, 2008 | 04:30 PM
V8hareed's Avatar
Car: 1991 Camaro RS
Engine: 350 ci
Axle/Gears: stock?
Okay now that I've made myself look like an idiot, I got my tach hooked up to the output on my msd box. The tach is dead on now, still a little jumpy, but It'll do the job until the autometer cluster takes over.
Jeremys87
Jul 14, 2022 09:08 PM
redmaroz
Aug 16, 2015 11:40 PM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
