Dead Speedometer
Old Sep 16, 2008 | 10:57 PM
L98 Z28's Avatar
Car: '92 Z28
Dead Speedometer
After 46k miles and 16 years, my speedometer has called it quits. It's a '92 with an electronic speedometer. I've connected to the ECM and I can see the correct speed, so its not VSS. I've pulled dash and tested using this method (posted here before):
Locate pin #2 and put ground on it. Locate pin #14 and put 12V on it. Then locate pin #1 and attach a wire to it. You will need a rasp or file. Ground the rasp/file and then take the wire from pin #1 and run it over the rasp/file at a decent speed. The speedometer should jump significantly. That will tell you that the speedometer is good.
The speedo didn't jump with this test, so the problem would be with the gauage console. People seem to just replace the speedo (which aren't readily available) instead of repairing it. Is there a reason for this?
Now, is the problem in the little circuit board or the speedo motor? The circuit board looks pretty simple, but it sounds like there isn't a known common problem with the boards? Cold solder joints, dead diodes, logic chip problem (seems unlikely)?
Or is the problem typically with the motor? Is there a way to test the motor? Is it a stepper motor? Is it a plain motor whose RPM is controlled to simulate a spinning cable? Is the pinout of the motors 4 pins available? Has anyone connected a microcontroller to the motor to test it directly (which uC & where's the code)? I've controlled servos with a rabbit uC, but not a motor.
Thanks for the help!
Joe
'92 Z28
http://home.cfl.rr.com/shuhy/chevy.htm
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Bigold4x4
Sep 28, 2015 05:21 PM
