17si to cs144 swap l69
Car: 1984 z-28
Engine: 305H.O. L69
Axle/Gears: 3.73 G80 GT4
okay, so 1200 miles after i start to drive i start to get the choke light coming on intermittently and low voltage, messed with connectors and it still occurs, seems to be heat sensitive.
both napa and checkers dont carry replacement alternators (sold out i think)
looked up and a cs144 swap looks good, bit more expensive but i'll pay that price to make it the last alternator my car will need
i see connectors/adapters for my 2 wire to its 4 wire plug, however, my questions are
How do i wire up an adapter i made myself (using cs144 plug and the 2 existing wires)
and is there any mounting difference? pulley swap needed?
i checked the
and couldnt find wiring diagrams, ie (this color to pin L)
any mounting issues i found in the search were for later models in which the alt is on driver side, mine is passenger, any help will be appreciated as i plan on doing this soon
no parts purchased yet btw
i checked the
and couldnt find wiring diagrams, ie (this color to pin L) any mounting issues i found in the search were for later models in which the alt is on driver side, mine is passenger, any help will be appreciated as i plan on doing this soon
Car: 1984 z-28
Engine: 305H.O. L69
Re: 17si to cs144 swap l69
here is a pic i found of the adapter i need to make.
they wont show which pins on the cs144 i need to connect the 2 wires to
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 1984 z-28
Engine: 305H.O. L69
awesome info on those links
would i need an adapter with or without the resistor in it?
not sure what the idiot light is on the dash or if i have one other than the choke and check engine lights
Chuck84TA
Jul 15, 2016 09:05 PM
Hello, Michael
Aug 20, 2015 03:19 PM
