What's the 2nd switch on the brake pedal
Old Sep 30, 2008 | 06:07 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
I know the top on works the brake lights and cruise.
What's the other switch do? Original auto car if it matters.
I broke mine, guessing it's not something I can get at the parts store.
Old Sep 30, 2008 | 07:57 PM
badtimmy1's Avatar
Re: What's the 2nd switch on the brake pedal
What color are the wires on the second switch?
Old Sep 30, 2008 | 08:09 PM
badtimmy1's Avatar
If the wire color is Yellow off of the switch, it's for the High-mount stoplamp. Is probably a dealer item. If CHMSL is inop, you can splice yellow wire into one of the other stop lamp bulb wires off of the stop lamp switch.
Old Sep 30, 2008 | 08:49 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
also it could be the switch the disengages the torque converter lockup. that would be my guess.
Old Oct 1, 2008 | 08:31 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
One is for the brakes (orange, yellow, blue), the other one is for cruise control (grey, brown).
Hope this helps.
Lou
Old Oct 1, 2008 | 05:02 PM
Aaron91RS's Avatar
Car: RS
Hope this helps.
Lou
The brakes and rubber hose for the cruise are on the same switch.
Here's a pic of what I broke.
It's got a total of 5 wires coming out of 2 connectors.
Old Oct 1, 2008 | 07:16 PM
i still say torque converter lockup
Old Oct 2, 2008 | 07:08 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
The brake light switch is a separate switch. I believe there might also be another plug in it...but its the one without the hose.
The switch with the vac hose and plugs is for cruise. Right now, with my T56/LS1 swap, Im ONLY running the brake light switch with the one plug in it. Thats it. Everything works 100%. If I wanted to finish hooking up the 4th gen cruise, Ide use a thirdgen cruise switch and just not hook up the hose.
As far as I know...the Torque Converter lock up uses the brake switch signal. But I never messed with the auto stuff long enough to learn it.
J.
Old Oct 2, 2008 | 09:01 AM
jccaclimber's Avatar
Car: 1991 RS Camaro
Engine: 350 0.060" over
If it's a 3rd brake light you should be able to turn your key to the on position (but not running) and then press the switch by hand. Have someone stand behind the car and see which lights you turn on.
Old Oct 2, 2008 | 03:49 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Lou is the correct one.
Orange is power to the switch. The yellow for the high mount stop lamp and the blue is for the tails.
The two brake switch wires for the converter are pink/black and purple
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
