battery relocation
Old Oct 2, 2008 | 12:04 AM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
battery relocation
I had a question before I do this.I`ve searched and never seen a really how to type thread.I `m` pretty sure I can handle running the wires and routing a vent tube through a hole in the rear with a grommet.What I have questions about is...
Under hood wires.After you run the wires from the trunk whats the best way to connect it to all the wires already underhood.Do you make something like a wiring terminal/block with the positive and negative coming from the battery.I`m thinking about haveing something with battery terminals or something to connect the wiring that is there and any future wiring.I`ve Never seen how this is done so sorry if this seems like a stupid question.
Old Oct 8, 2008 | 09:11 PM
Sevarg710X's Avatar
Car: 1990 Iroc-Z
Engine: 360 c.i.d
Transmission: WC t-5
Re: battery relocation
I've done this before on a nissan 240sx . You can simply run the ground from the battery to the chassis , you don;t have to run it all the way from the front of the car . Just be sure toground the motor to the chassis too . As far as the positive cable goes , it would be best to actually have all the wires connected some way directly to each other . Get it ?
Old Oct 9, 2008 | 04:51 AM
JohnZ28's Avatar
Car: 85 Z28
Engine: 383
Transmission: TH350
Axle/Gears: 3:73
I mounted a Ford style starter relay under the hood and moved all the connections off the starter to the relay.
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
drumstixer
Sep 29, 2015 03:02 PM
