87 camaro 5.7tpi blue wire(ground?) near pass. firewall. pic.
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 9 bolt Borg Warner Disk Brake Posi
so their is a blue wire that was taped the the outside of the wire harness loom and it comes out of the harness. its right by the heater motor.
i have a 87 iroc 5.7 tpi.
i see on a wire diagram the ecm has a dark blue wire that comes out and splits one to the fan press switch and one goes to no connection. im wondering if this is that wire with no connection or should it be grounded.
thanks
thanks
Car: 87 iroc z28
Engine: 5.7 TPI
Re: 87 camaro 5.7tpi blue wire(ground?) near pass. firewall. pic.
I have the same wire in my car. Mine is taped to the wiring harness with electrical tape. Don't know what it's for, but if all works dosen't matter.
Car: 89 Iroc
Engine: 5.7 TPI
thanks thats what i needed to know
Linson
Aug 21, 2015 02:12 PM
Street Lethal
Aug 12, 2015 11:33 AM
