Cruise control problems (already replaced servo and multiswitch)
Old Oct 22, 2008 | 11:19 PM
mrogers's Avatar
Car: '87 Camaro
Engine: 4.3L V6
Axle/Gears: 3.08
I've had my '87 Camaro for about a year and a half. I don't think the CC worked when I got the car and I didn't even try it until this spring. I've replaced the servo and the multiswitch. The servo is getting great vacuum even after the car is off so the back flow valve is working too. Brake vacuum and electrical switches are working correctly. The only two things left are the module and the speed sender in the speedometer. Am I wrong? What the odds of it being either of those parts? Any suggestions?
Old Oct 23, 2008 | 05:25 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Re: Cruise control problems (already replaced servo and multiswitch)
Your assumptions are correct. However, if the speed sender (& buffer box) isn't working then the ECM won't turn on the lockup as you get up to speed. So if the lockup works then only the CC box (& wiring) remains.
Old Oct 24, 2008 | 11:41 PM
mrogers's Avatar
Car: '87 Camaro
Engine: 4.3L V6
Axle/Gears: 3.08
I think the torque converter lockup worked when I bought it, but I switched engines and use a manual lockup switch now. Is the "buffer box" part of the cluster and therefore removeable from it, or does the whole cluster have to be replaced, and is the buffer box even a posible problem. I know there isn't a DRAC on the ECM bracket. I don't know how to proceed from here.
Old Oct 25, 2008 | 06:19 AM
I'm not sure about the maro, but on my Olds the buffer is separate from the cluster - hooked to the speedo sensor w a 3-wire (10-15") cable. It feeds the speed signal to the ECM on a brown wire, and the CC on a red wire. In the Monte the ECM also gets it on a brown wire, but the CC gets it on a yellow wire.
If you find a yellow wire on the CC-box you can try to monitor it w a voltmeter. It should jump up & down (12V/0V) as you slowly move the car.
Old Oct 25, 2008 | 11:18 PM
Daves03's Avatar
Car: 1991 Chevrolet Camaro RS Red
Engine: 305 V8 TBI
Transmission: TH-700R4
the speed buffer box is down next to your ecm under the passenger side dash, read my title (wiring) in the electronics threads i just went through problems with my speedometer and it may have touched on somethings you may need to know, there are wiring diagrams and some pictures for you to lookover that may help you. GOOD LUCK!
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Street Lethal
Aug 13, 2015 08:28 PM
stalkier
Aug 13, 2015 12:59 PM
Bull86
Aug 10, 2015 05:43 PM
