camaro starting issues
Old Nov 3, 2008 | 12:57 PM
berlinettajake's Avatar
Car: 84 camaro berlinetta
Engine: 383 stroker Bored .40 over
Transmission: th-400 hughes 2500 Stall
Axle/Gears: moser axles 3.73 gears
hey im pretty sure nobody knowns whats going on but here we go. I have a 84 camaro berlinetta and every once and awhile i will drive it and shut it off, get back in and i try to turn it over and nothing no starter click no sound nothing. when you turn the key the dash turns off (i have a electronic dash) until you let off of the key then everything comes back on. But get this, It has been doing this for awhile and my buddy was with me and jokingly pulls my e_brake and says "now try it!" and it worked.. now so far every time it does it i pull the e-brake up and try and start it it works, then put the e-brake back down.. my e-brake isnt even hooked up. but someow works like a charm. i have a new battery new starter new wires new ignition switch new neutrul saftey switch. still does this.. any help would be great!
Old Nov 3, 2008 | 08:31 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: camaro starting issues
I'm not going to chase down the bug - but I remember something from a long time ago when I read your post,.......... If I find the wiring diagram I'll post it for Ya' !
I was trying to test hatch releases to be sure the one I had sold was working. When attempting to get the hatch solenoid to work I found it was dead and couldn't understand why. Once I chased down all the wiring I found that it has something to do with the starter. Once I attached the starter to the system - the hatch solenoid worked. I believe that this is true ONLY on the automatic tranny cars. Was your cars tranny converted ??
Edit:
Found it - Learn what you can !
Old Nov 3, 2008 | 11:38 PM
awesome il try and track this down thanks for the help!
Old Nov 7, 2008 | 01:46 AM
Kandied91z's Avatar
same thing happen in my 91 as electrical or not most guages move when the key goes forward. turns out the ignition was shot. don't rely on those little tricks such as the emergency brake as the next time it will be when you have to get somewhere. fix it asap.
Old Nov 7, 2008 | 01:29 PM
im not sure where to start on this because iv taken it in several time to get it fixed but they put a new part in and say its fixed when its not. so im not sure what to do or how to fix it.
Frozer!!!
Jan 19, 2024 04:55 PM
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
mizz0313
Aug 12, 2015 06:45 AM
86Base
Aug 8, 2015 01:34 PM
