Reverse lights not working
Old Nov 14, 2008 | 12:09 AM
Guro 305's Avatar
Car: 1986 Pontiac Firebird S/E
Engine: 305 carb'd V8
Transmission: 4-speed auto
Axle/Gears: Stock
Checked the bulbs and switches, both look good. Switched bulbs and switches.....nothing. Any ideas?
Old Nov 14, 2008 | 10:07 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Reverse lights not working
Have you used a test light (or voltmeter) to check the voltage at the switch and at the bulbs?
Lou
Old Nov 14, 2008 | 10:33 AM
brodysZ28's Avatar
Car: 1983 Camaro Z28
Engine: 383
Transmission: TKO 600
Axle/Gears: Strange S60
check where it plugs into the transmission. maybe it popped out.
Old Nov 14, 2008 | 11:17 AM
Guro 305's Avatar
Axle/Gears: Stock
That's what I was thinking. I ran over some roadkill on the Turnpike awhile ago. It was a real real big hit.....like a dead dog. Didn't really notice it until recently. Do you know what is the name of that switch that plugs into the tranny?
Old Nov 14, 2008 | 11:17 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
It's called a back-up light switch.
NAPA part ECH NS6574
http://www.napaonline.com/MasterPage...p+Light+Switch
Old Nov 15, 2008 | 01:52 AM
Guro 305's Avatar
Axle/Gears: Stock
Thanks man. Hey, since we're at it is there one on the tranny for the odometer also?
Old Nov 15, 2008 | 03:00 PM
brodysZ28's Avatar
Engine: 383
i think there is just the speedometer cable.
Old Nov 21, 2008 | 09:58 AM
Guro 305's Avatar
Axle/Gears: Stock
Folks at Advance Auto said that the back-up light switch is for a manual tranny and the neutrel safety switch is for the auto. Is this true?
Old Nov 21, 2008 | 01:14 PM
BigBadLou's Avatar
Engine: TPI
Absolutely.
For the automatics, the shifter switch turns on the reverse lights. It's the dark blue and light green wires.
Hope this helps.
Lou
Old Nov 21, 2008 | 06:45 PM
Guro 305's Avatar
Axle/Gears: Stock
Originally Posted by BigBabyLou
Absolutely.
Hope this helps.
Lou
Yes it does bro, thank you!
Old Dec 21, 2008 | 09:45 PM
Guro 305's Avatar
Axle/Gears: Stock
Re: Reverse lights not working.....UPDATE!!!!
I changed out the neutral safety switch and problem is solved. This case is closed!
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
hokis
Aug 9, 2015 03:57 PM
