H4 high beam help needed
Old Nov 15, 2008 | 06:47 PM
Bowtiebruiser's Avatar
Car: 1982 Camaro Z-28
Engine: 350 4bbl
Transmission: Borg Warner Super T-10
Axle/Gears: Richmond 10 bolt 4:10 Posi
I am using a set of the projector housings I got from Ebay, they came with H4 bulbs for all 4 housings, the lows plugged right in, my high beams are a 2 blade connector, any ideas?
Old Nov 16, 2008 | 05:08 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: H4 high beam help needed
H4 bulbs are typically not used in the high beam position. The only other thing I can add is that the high beams use a single filament bulb, which the H4 is not.
You need to find a single filament bulb that will fit your housing. But I doubt you'll find one if the housing is made for an H4 bulb.
Single filament bulbs I'm familiar with are the H1 and H3, have a different "base" than an H4.
You can use the H4 as a high beam if you figure out which terminals are gound and the high filament. Make a couple of jumper wires from your existing terminal to the bulb. You'll have one unused terminal on the bulb. Can't say for sure if the beam pattern will be good though. There's another thread here that you started that explains this.
Old Nov 16, 2008 | 11:51 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
H4 headlights also require the connectors to be repinned because the Hi/Low/Ground are rotated 1 pin to the left as you look at the back of the light.
https://www.thirdgen.org/tech/images/connect.gif
For my highs (inner lights), I wired the two together so that I used both filaments as a high beam light, this also requires a slightly larger fuse because you have twice the current draw. My Hi/Low beams (outer pair) I repinned and left alone, but of course I built and installed a kit similar to the one in the tech articles.
https://www.thirdgen.org/headlightupgrade
Old Nov 17, 2008 | 10:48 AM
Engine: 350 4bbl
You got a diagram for that repin, cause my low beams are just plugged right in and they work fine, but if it's not right then I need to fix it, also I bought an H4 plug like the one for my low beams to I can try and get this to work right
Old Nov 17, 2008 | 08:28 PM
Al Hasse's Avatar
Check the links in my previous post. Those came from the tech articles on the home page.
Old Nov 17, 2008 | 08:48 PM
Engine: 350 4bbl
So which one is for the high beam the top one or middle one? I cant read the text it's all choppy
Old Nov 17, 2008 | 09:00 PM
Al Hasse's Avatar
Why would the text be all choppy?? It's an image and posted in the tech article as an image.
The top diagram shows the back of an H4 bulb. Hi/Low, doesn't matter, for your high beams, just use the 2 opposite pins and you'll be fine.
The middle diagram shows the back of a sealed beam light (like stock) for the Hi/Lo, or outside pair of lights.
Old Nov 17, 2008 | 11:42 PM
Engine: 350 4bbl
Aaaah cool thanks man I appreciate the help
IROCZ1989
Jan 24, 2016 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
