I Need Heat, What's Needed?
Old Nov 21, 2008 | 03:47 AM
Sooo_slow's Avatar
Car: 82 Z28
Engine: 327
Transmission: TH350
Ok, so I have an 82 Camaro. Currently 327, carb. It has no heater box, no heater wiring (in engine bay), has heater core, and interior heater wiring. I have the interior heater control unit.
What all do I need to get some heat/defrost in this puppy?
I will most likely be doing the s10 heater delete box, but I need to know if I would be able to wire everything up myself, or if I need certain resistors..etc
The heater hose will be no problem.
Looked at austinthirdgen's wiring and its a little confusing. Is the resistor in the motor or box or additional?
And where would the blower relay be located as well.
Thanks in advance
Old Nov 21, 2008 | 07:05 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: I Need Heat, What's Needed?
A pic in the following link may be helpful:
https://www.thirdgen.org/forums/cool...er-heater.html
JamesC
Old Nov 21, 2008 | 06:33 PM
Sooo_slow's Avatar
Car: 82 Z28
Engine: 327
Transmission: TH350
So I guess I'll have to find the resistor off another car, or essentially if I only needed one speed I could just wire it one wire from the switch to the relay/motor and eliminate the resistor completely?
*EDIT* the box I'm planning on buying already has a resistor, although it it for an s10, would I need to change it to a camaro specific one or just wire it up and go with however many speeds it has?
Old Nov 21, 2008 | 06:44 PM
JamesC's Avatar
Just asking b/c I'm not sure how easy the resistor will be to find.
Shouldn't be a problem: Any junked 82-92 Camaro will have one.
JamesC
Old Nov 21, 2008 | 06:55 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
You can also buy the blower resistor at Autozone, O'Reilly, etc.
Old Nov 21, 2008 | 09:10 PM
JamesC's Avatar
Originally Posted by Ward
You can also buy the blower resistor at Autozone...
Yep. DR777 at $11.99.
JamesC
Old Nov 21, 2008 | 09:35 PM
Sooo_slow's Avatar
Car: 82 Z28
Engine: 327
Transmission: TH350
Perfect, thanks for the responses.
So all I will need is the heaterbox/blower motor/cage, resistor and relay, then it's pretty much some wiring and throw some hose onto heatercore and it should be good to go?
Old Nov 22, 2008 | 06:34 AM
JamesC's Avatar
Sounds about right.
JamesC
Old Nov 22, 2008 | 02:55 PM
Sooo_slow's Avatar
Car: 82 Z28
Engine: 327
Transmission: TH350
Ok, so it sounds pretty straight forward and with the wiring diagram it should be simple.
One last question
Is there some sort of gasket or anything that goes between the heaterbox and firewall?
If so could I just silicon it if needed?
Or is it a little foam seal?
Old Nov 22, 2008 | 03:07 PM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
I used black RTV all the way around the box, let it sit overnight to settle then installed it, no gasket that I know of.
Old Nov 22, 2008 | 04:54 PM
JamesC's Avatar
Strips of automotive caulking work very well.
JamesC
Old Nov 22, 2008 | 06:37 PM
Sooo_slow's Avatar
Car: 82 Z28
Engine: 327
Transmission: TH350
Awesome, thanks for all the help.
IROCZ1989
Jan 24, 2016 03:55 PM
mustangman65_79
Sep 1, 2015 03:51 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
