Alternator wires, Where do they go?? 1989 RS
Subscribe
Dec 9, 2008 | 08:42 PM
Ok guys this question has been asked a million times bt I cant find a strait answer. I searched but to no avial. I have an 89 RS camaro 355 swapped'. I need to rewire the alternator, I have a large red wire (dist. block) (bottom of alt.)........ Then there is a (approx 12 guage) red wire from the 2 wire plug, then laastly a white/brown stiped wire.
Now, i have read that the brown wire is the one I need to wire to the factory guage cluster plug on pin c100 or something???
Also the red wire is just go ahead 12v. So I assume to just wire it to the bottom BATT post of my alternator. Not sure.
I appreciate any help or suggestions. I would like to go 1 wire but it wont fit the stock serp bracket.
Reply 0
Dec 10, 2008 | 04:20 AM
Re: Alternator wires, Where do they go?? 1989 RS
i can send you the factory wiring chart but i need an email address because i dont know how to get a picture from my computer into this thing as it keeps asking for a url and i dont have a separate site for it.
not sure if that did it or not
pm me with e-mail address
Reply 0
Dec 10, 2008 | 04:29 AM
you really need the wiring diagram. there are 4 possible fusible links and the brown wire goes into a 20 amp fuse box inside the car.
i wish there was a way to insert a pic from our computer into the answers. im sure that there is but i cant figure it out.
maybe this did it. yes it got in. click on it and its the factory wiring for that issue.
Reply 0
Dec 10, 2008 | 06:50 AM
Treat the connector in the following link as a two-wire connector and you'll have what you need.
http://paceperformance.com/index.asp...=Custom&ID=650
JamesC
Reply 0
Feb 1, 2009 | 12:28 AM
Thanks for the good pictures. I am in the process of finishing a BBC swap I started years ago and this was a good refresher. It was a little tricky picking back up on a half wired project from years ago.
Reply 0
Subscribe
