Power locks are both dead
Old Dec 10, 2008 | 12:29 PM
MYZ28NH's Avatar
Car: 91 Z28 Convertible
All my electronics are fine except my power locks. Did some searches but can't find my answer. The fuses are all fine so it's not that. Is there a relay in the fuse box that could be bad and killing both switches? If so which one is it? A relay is not like a fuse, you can't just look at it and tell if it's bad. Is there some other component elsewhere that could be the trouble? It is a 91 z28. Also the power windows both go up and down real slow, does that mean both motors are going? If so why would both motors develop the same problem at the exzact same time. The battery is fine. Thanks Mike
Old Dec 10, 2008 | 02:24 PM
Steveh4263's Avatar
Car: 1987 Pontiac Trans AM GTA
Engine: 5.7 LTR
Transmission: Automatic
Re: Power locks are both dead
Do the power door locks move at all? If they do move they just might need a good greasing with lithum grease. I would do this to the power window motor and the metal guides that help move the window up and down. You'll have to remove the door panels to do this and remove the plastic that covers the door so you can get at the door locks and window motors etc. I did this and my door locks work fine now. My windows still seem a little slow, but it is a vast improvement.
Old Dec 10, 2008 | 02:41 PM
MYZ28NH's Avatar
Locks are completley dead......nothing
Old Dec 10, 2008 | 03:00 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Try this simple tech article on troubleshooting door locks.
Hope this helps.
Lou
Old Dec 10, 2008 | 04:00 PM
Steveh4263's Avatar
Engine: 5.7 LTR
Wow thanks for the information and the web site.
Old Dec 10, 2008 | 06:36 PM
MYZ28NH's Avatar
I' do the trouble shooting tomorrow if it ever stops raining.
Old Dec 10, 2008 | 08:13 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
PDL relay is bolted to the body behind the driver's side kick panel, by your feet. It's a golden colored dual relay box... One being for "Lock" and the other for "Unlock". If the bolt is loose, you will lose your door locks, since the relays both ground through the bolt...
Old Dec 11, 2008 | 08:11 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
There are 2 metal circuit breakers in your fuse-box. One is for the windows and the other controls the power locks. Since you know the windows are working - swap the 2 circuit breakers and re-check the Locks and Windows.
Most power lock problems are due to corrosion at one (or more) of the system connecting points. Many time a power lock system can be fixxed by cleaning all the connecting points. Start at the buttons and that harness, and them clean the plugs and the connection at each power door lock. ( Your door lock relay is NOT grounded to the body. That was in done in the earlier cars; your VATS starter enable relay should be mounted in that spot ! )
The Power locks in my last IROC didn't work at all when I got the car. After cleaning up the connections I now have both buttons and 1 power lock working ( 1 lock dead )
As far as the speed of your windows - they are all slow ! Since you will need to remove the door panels to clean ( or possibly replace ) the lock soleniods it's a good Idea to grease the window tracks and lube the power door lock systems while you are in there. A well lubed set-up will work much better than one that's dry and crusty. Keeping the window seals soft and treating the glass with Rain-X also helps the windows operate faster.
Old Mar 9, 2009 | 08:10 PM
kallark's Avatar
Car: 1992 Z28
Engine: 350TPI
Transmission: 700R4 Auto
Axle/Gears: G92
I have a similar issue, one day both doors stopped opening. I can actually hear the relay clicking beside the kick panel when buttons are pressed, but nothing is happening. I read the article, but cant find the CTSY fuse, its not in my fusebox... The other one is PWR ACC is good. Any help? Thanks!
Old Mar 10, 2009 | 05:52 PM
BigBadLou's Avatar
Engine: TPI
Maybe this would help?
Hope this helps.
Lou
Old Mar 31, 2009 | 06:33 PM
da_jester's Avatar
Car: 1992 camaro rs
ok ive got one for you guys then im having kind of the same issue and ive tested i have power on orange wire at both switches and they unlock but they dont lock.both switches unlock but neither lock the doors any ideas?
Old Mar 31, 2009 | 08:52 PM
BigBadLou's Avatar
Engine: TPI
Hope this helps.
Lou
Old Apr 1, 2009 | 01:49 PM
da_jester's Avatar
Car: 1992 camaro rs
ok so i tested the orange wire on back of switch has 12 volts push unlock button blue wire gets 12 volts but when i push lock nothing on the black.so i jumped from the orange to the lock wire and the relay clicked but locks didnt move.same thing at relay.i dont see as how the motors could be bad if they unlock but dont lock. but if i put 12volt to lock at the relay samething clicks but doesnt move.ive cleaned and greased both doors work great by hand but they wont lock electronicaly.so any ideas what it could be im lost.thanks in advance.
Old Apr 1, 2009 | 02:31 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
i have one that will not lock unless i hit unlock first and unlock the doors. not sure why but if i do that they both unlock then when i hit lock they both lock.
its almost like they dont want to lock unless they see you used the unlock. must do something to the main switch.
Old Apr 3, 2009 | 08:08 AM
da_jester's Avatar
Car: 1992 camaro rs
well after testing everything and taking one of the switches apart i found out that the lock buttons on both my switches dont work.i should have relised it before because when u push the lock as aposed to pushing the unlock it feals like theres nothing there.
BRoss99
Aug 10, 2025 05:08 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
mantaguy
Sep 1, 2015 08:39 PM
sailtexas186548
Aug 24, 2015 10:11 PM
zayne0
Aug 24, 2015 07:22 PM
