Light above HVAC controls
Old Jan 24, 2009 | 04:09 PM
  #51
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: Light above HVAC controls
Originally Posted by RTGTA
Man that looks pretty good. Any chances of getting a better quality pic?
well one of 2 way will make it, 1 i find the programing to my digi, or 2 my friends comes over and lets me use his digi.......either way i hope to have a better pic of it....
but i love it, it turned out great
Old Feb 19, 2009 | 08:04 PM
  #52
89RS_82Z's Avatar
BUMP/ update
i cant seem to get a better pic with my friends digi, it looks fine on the screen and when you click it turns to crap
Old Feb 20, 2009 | 09:49 AM
  #53
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Originally Posted by 89RS_82Z
umm yea scratch that last message LOL, i just went to replace the bulb in mine and take a pic, and realized i have no bulbs in its size, but i will leave you with this, its a LED light i put in my center console, its wired to the dash lights, it really helps to find stuff at night, all it is, is a white led from rat shack, got a resistor and a led holder for it, looks good, works and its bright, pics you really cant tell....i used the hole thats inthe console from the factory, i think its the hole that the adjuster for the center console clock went, so if you got the center console tic toc than you need to drill another
hole
how do I replace my console light with leds? would bulb did you use?
i think my console light fell inside the console
Old Feb 20, 2009 | 04:18 PM
  #54
89RS_82Z's Avatar
i used the same LED as i did on the post above for the ashtrey light, there was no stock bulb in the console
Old Feb 22, 2009 | 11:46 PM
  #55
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Originally Posted by 80schild
My GTA has the light there, but it's not LED. It has a red bulb in it to match the switches and gauges. I really don't understand the purpose of the light since the heater/ac and stereo controls are backlit. Maybe it's meant to provide a little light for the ashtray.
I with my T/A had this light. I swapped in a Monsoon Stereo so I could play CD's but none of the buttons are lit, only the display...I can't see what I'm trying to do on it without turning on one of map lights or the dome light.
Old Feb 23, 2009 | 03:24 PM
  #56
89RS_82Z's Avatar
make one, get a red LED and not a white one, problem solved......but i think the red will not provide the light you need
Old Feb 25, 2009 | 12:14 PM
  #57
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Wouldn't painting the lens with a translucent red paint work with a bright white L.E.D.?
Old Feb 25, 2009 | 12:31 PM
  #58
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
That would dim it.
But transparent bulb dip would work.
But the best way is to use a LED intended for traffic signals.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
How bout those dorks too scared to drive without headlights in the daytime!
Old Feb 25, 2009 | 01:47 PM
  #59
Aarons92Maro's Avatar
Car: 1992 Camaro RS & 1994 Mazda 626
Engine: 305 TBI V8 / 2.0 4-cyl.
Transmission: 700R4 / I have no idea
Axle/Gears: Stock 2.73 / I don't know
This is going to annoy the hell out of me. I just went to see my car two weekends ago and I didn't even know these lights exsisted... didn't look. I haven't noticed anything while driving it, but it may be burned out or U didn't see the light.
Could my car have it? I hope it does!
Options are:
T-tops,
Power windows,
Power locks,
Power hatch,Daul reading lamp mirror (w/ map light that comes on when running lights/headlights come on),
Defrost (rear),
F41/Z28 handling/rims.
No power seats.
I won't see my car again until April most likely.
Old Feb 25, 2009 | 02:13 PM
  #60
Originally Posted by JamesC
The light is OE--at least on Camaros of this vintage. A search will provide a ton of info.
JamesC
Where is all this INFO? I'm not finding anything.If anyone knows any links or finds info, please post the links. I want to know if my car has this or not. It's amazing how popular this little light is! There's probably people all across the US running out their cars and looking for these little lights like little kids running out to see what Santa brang on Christmas day!
Old Feb 26, 2009 | 03:43 AM
  #61
KITT1983's Avatar
when you find the info please tell me thanks
Old Apr 1, 2009 | 06:57 PM
  #62
aldaran's Avatar
Once you take off the 2 screws does the housing pop off? I have the two screws in the location mentioned, but I can't tell if a light is in there or not. I removed the screws and the piece still seemed pretty tight in place.
Old Apr 1, 2009 | 07:07 PM
  #63
89RS_82Z's Avatar
push foward or pull back on it, look in my pics of the conversion you can see it has a tab on it to hold it in also
try that, it that dont work PM me or post up
Old Apr 1, 2009 | 07:08 PM
  #64
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
The light is behind the third little square thing in the middle of ur pic..You do have the light.I had to gently pry mine with my pocket knife.
Old Apr 7, 2009 | 04:47 PM
  #65
MY87LT's Avatar
Car: 1987 Camaro LT
Both previous posts are just what I did to get mine out. That light tends to get stuck after years of not knowing it was even there. But being very patient and careful to remove it is very important.
Old Apr 7, 2009 | 04:57 PM
  #66
KITT1983's Avatar
my console light fell into the console
Old Apr 28, 2009 | 09:06 AM
  #67
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
I never knew that light was there until i went over a bump and the whole thing fell down and out of the dash lol.
Old Apr 28, 2009 | 04:52 PM
  #68
MY87LT's Avatar
Car: 1987 Camaro LT
Put in an L.E.D. this weekend I bought to replace the standard glass bulb. The bright white one worked really well. I also bought a red one and that was a more subtle ambient light that worked great with my red interior. The L.E.D.'s were direct plug in without any modifictation. The only thing you need to do is make sure you install it on the right polarity. If the light does not go on when you turn on the parking or headlights, you need to remove the bulb and rotate it. http://www.ledlight.com/t5-74-automo...ed-lights.aspx
I bought T5 Wedge Round LED Light Product Code: 43264
Old Sep 12, 2009 | 07:50 PM
  #69
84ws689bird's Avatar
Car: 1988 IROC
Engine: 5.7
Axle/Gears: 2.77 posi
The reason all cars have the two screws is they also hold a metal bracket used for securing the center part of the dash. if you remove the dash pad itself, you can access the top of the light, if it's there, without having to remove it from the lower side and possibly breaking it. I use the metal bracket to hold my gps antenna under the dash. My car also has the light.
Old Sep 18, 2009 | 10:39 PM
  #70
Guy In A 90 RS's Avatar
Car: 1990 Camaro RS
Engine: 3.1 V6 MFI
Transmission: MD8 Hydra-Matic 4L60
Axle/Gears: Standard/3.23
For some reason or another, that doesn't seem to apply with the 90-92 cars. . .The whole light assembly just snaps into place. There's no screws at all. Probably to avoid cracking plastic. I have a 90 which was missing when I bought it- just a big gaping hole- and pulled one out of a 91 or 92 car at a junkyard.
Old Feb 16, 2010 | 05:33 PM
  #71
POPODYNAMO's Avatar
Car: 84 Camaro Z28
Engine: 305 HO
Transmission: 700-R4
This might sound dumb but im a new person and i was wondering if u guys could tell me where all of the lights are for those little spots like under the vent and inside the vents
Old May 6, 2011 | 04:48 PM
  #72
Cpt Vos Bradley's Avatar
Car: 1989 Camaro RS
Engine: 2.8L V6
Transmission: W/C T5
I'd just like to confirm that the 89 Camaro RS does indeed have the light.
Old Oct 13, 2011 | 12:22 AM
  #73
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
My '86 Z does NOT have a lamp above the HVAC controls. There is no lamp any where under the dash pad. The only lamp for the HVAC is the 194 bulb that backlights the control panel. What I do have is a dome light with two push button lights that are aimed towards the lower part of the dash which I think are usually refered to as map lights.
Old Oct 14, 2011 | 10:39 PM
  #74
89RS_82Z's Avatar
its seems to be very unclear what options gave you this light to light up the ash trey area
i did see one time at a j/y a neat light, it has a fiber optic tube plugged into the shift indicator, and then connected to the ash try its self to light it up
Old Oct 15, 2011 | 02:32 AM
  #75
Ozz1967's Avatar
Car: 1984 Trans Am
my 84 T/A does not have a light above the HVAC controls. While those controls are backlit, I retrofitted a 2000 Camaro radio into my 84 T/A and it's controls are not lit at all...so doing anything with the radio at night is guess work. which means that I will probably be fitting a light there some day.
Old Nov 2, 2012 | 01:34 AM
  #76
salfirebird92's Avatar
Car: 92 Firebird Formula
Engine: 5.0 V8
89RS_82Z What size is the led light 3mm or 5mm I only find Blinking led light in ebay please help. I have a question is it possible to put led lights with a regular autozone switch in siri mode I'm planning to put 2 in the hatch area and one in each side of the of the driver and passenger side like the courtesy lights in my 92 Firebird so that would be 4 lights running siri mode. If so what do I need Sorry for all the questions thanks.
Old Nov 3, 2012 | 12:52 AM
  #77
Engine: 5.0 V8
I meant trying to connect 4 leds in a series mode not siri lol.
Old Nov 28, 2012 | 04:41 PM
  #78
89RS_82Z's Avatar
5mm
http://www.radioshack.com/product/in...ductId=3060980
Old May 17, 2019 | 09:14 AM
  #79
PAformula's Avatar
sorry to bring up an old thread, but i had my dash apart and noticed my '91 GTA has a hole in the center bezel for a light but no light or pigtail is there (unless someone buried out of site). Anyone have a pic of the stock light that would be in the 90-92 firebirds. TIA
Old May 17, 2019 | 11:30 AM
  #80
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
The later Firebirds have a light in the mirror that comes on with the exterior lighting, to illuminate the shifter area. One side under the mirror is the Map light, the other is the night illumination. The light shines through a small slit in the bottom of the housing
Old Jun 20, 2019 | 06:08 AM
  #81
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
I needed to repair my broken shift indicator on my console.
Somebody pushed to hard and broke the melted fastner tab so it need a reglue.
When I removed it I found what looks to be a ashtray "fiber optic" light.
First one I have ever seen! Only seen the lights in the base of the center vents before.
https://www.thirdgen.org/forums/body...ray-light.html
Old Jun 20, 2019 | 05:13 PM
  #82
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Waitin till dark to take a pic of how well that "fiber optic" works and take a pic!
Cant get a pic of how well it lights up either in the ashtray or PRNDL display at nite.
But its fixed and works!
Old Jun 21, 2019 | 01:58 AM
  #83
Drew's Avatar
But... There is a lamp module that fits the hole in the middle bottom of the accessory switch panel on 90-92 Firebirds, it's just redundant. Probably why most 90-92 Firebirds don't have the lamp or the wiring for it. It does exist though, and some Firebirds have (had?) it. It's just a 1/4 turn lock, self contained bulb with a red plastic lens. The bulb can't be replaced, and it doesn't put out enough light to worry about.
Old Jun 21, 2019 | 10:26 AM
  #84
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Great ash tray light thread here:
Casey Meyers
Mar 2, 2016 10:46 AM
Winchester1094
Interior Parts Wanted
Aug 19, 2015 05:01 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
