Bad ignition switch??
Old Dec 19, 2008 | 01:51 PM
87Red305's Avatar
Car: 1987 Camaro
Engine: 305 v8
In my 87 Camaro, you dont need the key to start the car. you can actually turn the ignition and start the car with nothing in it. What component needs to be replaced, is it the ignition switch? My dad mentioned that it could be a cable OR the ignition switch. How hard is this job? Something I could do?
Old Dec 19, 2008 | 03:41 PM
mark wells's Avatar
Car: 85 Trans Am
Engine: 383 ci
Axle/Gears: posi 342
Re: Bad ignition switch??
If your car does not have an Air bag it is very easy, get a steering wheel puller (buy or rent) purchase a new ignition switch. Pull steering wheel, remove the 3 screws holding the turnsignal switch and the 1 screw holding it to the lever. Carefully move the turnsignal assembly out of the way. remove the one screw holding the ignition switch in and pull out. Installation is the reverse.
Old Dec 19, 2008 | 03:45 PM
87Red305's Avatar
Car: 1987 Camaro
Engine: 305 v8
Oh, that doesn't sound too bad! Thanks Mark!
BRoss99
Aug 10, 2025 05:08 PM
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
Bryan F
Aug 18, 2015 02:28 PM
djmarch
Aug 9, 2015 05:27 PM
