Simple question, interior light + power locks?
Old Dec 21, 2008 | 08:33 PM
JungleMan's Avatar
Car: 91 Firebird, white
Engine: L03 :(
Axle/Gears: 4th gen, 3.23
Simple electrical question... just recently my interior light and my power locks both stopped working. Either this is a really big coincidence or maybe they're on the same fuse and I just need a new one.
Can someone point me in the right direction? Much appreciated.
Old Dec 21, 2008 | 09:03 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
Re: Simple question, interior light + power locks?
they are on the same fuse, along with the cig lighter and a couple other things i can't remember. check your fuses.
Old Dec 21, 2008 | 09:31 PM
Arizona IROC's Avatar
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
Cig lighter might be the problem.
I replace mine and everything works perfect now
$7 at Autozone. Of course you need to replace the accessory fuse
Old Dec 23, 2008 | 05:23 AM
JungleMan's Avatar
Engine: L03 :(
Thanks. If anyone could post up a fuse diagram or something, so I know which fuse to replace, that would be helpful. Both are cheap fixes but I'd rather try the fuse first.
Old Dec 23, 2008 | 03:54 PM
QuickStyle's Avatar
Car: 91 Z28
if you look at the fuse block, they are all marked what they are for. the one you are looking for is marked ACC or accessory
Old Feb 27, 2009 | 10:00 AM
350TPI_GTA91's Avatar
Car: 1991 Trans Am GTA
Engine: 350TPI 5.7L V8
Transmission: 7000r4
I just had the cigarette lighter replaced as suggested by many and today during a ride the acc 20 fuse burnt out again and when trying to replace it burns out again.
Looks like there's still a short circuit going on, any idea where to look next if it's not the cigarette lighter causing the problem?
And another strange this is, why when the mechanic replaced the cigarette lighter it worked all perfectly fine. Things always seem to happen when leaving the mechanic :-)
Old Mar 1, 2009 | 09:47 AM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
that's what happened to mine. just a fuse. put a new one in and things were working that i had no idea didn't work. i was only after to turn on the interior light.
Old Mar 1, 2009 | 12:48 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Have you been under the hood?? If equipped, the under hood light is on that same fuse, had to disconnect mine to keep the fuse from blowing.
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Omega
Aug 10, 2015 12:46 PM
camaroken83
Aug 10, 2015 11:35 AM
