Vehicle Speed Sensor ??? how to test
Car: 88' Trans-AM WS6
I Need information on the VSS in a 1988 trans-am with a 305 TPI.
I think it produces 2000 pulses per mile.
12vdc pulses? Can anyone help me troubleshoot please
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
THE NEED FOR SPEED . . . . . . . . . SENSOR
The VSS outputs AC which is converted to DC VIA a buffer or the ECM depending on engine configuration.
To test the VSS connect an oscilloscope to observe the waveform.
In lieu of a scope use an audio amplifier.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Re: Vehicle Speed Sensor ??? how to test
Try this: locate the VSS pin on the ECM and hook a voltmeter to it. Moving the car real slow (with ignition) on should make the meter jump up & down if it has an optical speedometer sensor with buffer. If it has an inductive tranny mounted speed sensor you'll need a little more speed and a scope to see what happens. Or use the audio method as NINÅ suggests, it also works. A 10k resistor in series with a pair of earphones is the simplest method.
ambainb
Apr 25, 2016 09:21 PM
GVMV
Aug 16, 2015 08:01 PM
