winshield wipper problem
Old Nov 30, 2008 | 10:58 PM
87transGTA's Avatar
Car: 87 GTA
Engine: 350 Tune port
Transmission: 700r4,2500 stall
ok heres my problem- when i turn the wipers on its just one steady speed well the speed has no delay and even on low it does that only time the speed is diffrent is when its on high and occasionally they turn off and when im tryin to turn them off i have to slowly turn it to the off position and like feel it engage and this has been buggin the crap out of me these past few days cause its been rainin alot so any suggestions would be really apreciated thanks in advance
Old Dec 3, 2008 | 10:46 PM
RTGTA's Avatar
Car: 2009 Silverado 1500
Engine: 5.3 Vortec
Re: winshield wipper problem
I'm guessing wiper motor.... My truck was doing that same thing and that was the problem. Or also try the multi function switch
Old Dec 4, 2008 | 08:26 PM
lunaticinaZ's Avatar
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
i had a 1988 broncoII and i had to get out and hit the wiper motor just to get it to work. and it only worked on high, if i put it on delay it would stop working. i replaced the motor and it still did it but i didnt have to hit the motor. so i replaced the wiper switch and never had the problem agian. so i agree with rtgta. replace the switch and if that dont stop it. do the motor.
Old Dec 5, 2008 | 08:30 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
The delay circuits inside the wiper motor cover are probably burnt out.
It sounds like when the wipers are working at full speed and you turn the lever back ( into the DELAY zone on the lever ) the wipers stop working until the lever is turned all the way to LOW or OFF. If that's true that the delay switch in the lever is working,...... The motor realizes that the lever has moved from HIGH to DELAY - but the delay circuits are blown out so the wipers do not respond. Once the lever reaches the LOW or OFF setting; they work again. (This is exactly what happens when a non-delay wiper motor is installed on a car that had delay wipers from the factory. )
Replace the Motor before replacing the lever - or at least probe the wiper wires with a voltmeter at the bottom of the cloumn before buying parts to be sure.
Old Dec 6, 2008 | 10:54 AM
87transGTA's Avatar
Car: 87 GTA
thanks alot you guys im going to go ahead and swap out the motor since the washer pump doesnt work either, so how would i take off the control switch on the colum
Old Dec 6, 2008 | 11:03 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
if you only have one speed it what is it? if it is HI then you are bypassing everything and going right to the motor via the purple lead.
if it is low then you still have part of the circuit and are using only the grey lead.
in any event you problem is not the motor, if it works at all then its fine.
your problem is via the green or pink leads that control variable hi/lo or pulse delay, respectively.
so pull the green and pink leads - mark them - see if there is any difference.
if not then pull the purple lead and see if it still works and if it does then switch the purple and grey to see if you have any speed change.
at least you will know that the switch still works in HI/LO mode.
in any event - its not a motor problem. if the motor works at all then it works.
Good luck
Old Dec 6, 2008 | 11:15 AM
87transGTA's Avatar
Car: 87 GTA
Good luck
well i only have a slow speed well it wipes down the goes back up and it will ocasionally stop and when i turn it to low on the switch its still the same speed and trough the whole delay marks on the switch its also the same only time the speed of the wipers is diffrent is the hi on the switch. The pink and green leads are they on the motor or on the colum?
Old Dec 25, 2008 | 10:37 PM
87transGTA's Avatar
Car: 87 GTA
anyone have any suggestions still stuck dont know where to start??
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
