No Trouble Codes??
Old Dec 24, 2008 | 05:04 PM
WhtIroc's Avatar
No Trouble Codes??
My 87, Carbed, 305 V8 Camaro doesn't flash trouble codes when A and B are jumped. It stays lit while running, and while the key is in the on position.
Old Dec 24, 2008 | 07:48 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: No Trouble Codes??
1. Is the CEL on without A&B jumpered?
2. Try this: With the key OFF, jumper A&B. Then turn the key to ON (don't start the engine). Does the CEL flash now?
Old Dec 25, 2008 | 01:34 AM
kcb37's Avatar
Are you jumping these two terminals?
Do it with the key off, then turn it to run and it should flash.
Old Dec 25, 2008 | 01:21 PM
WhtIroc's Avatar
Yeah the CEL is on whenever the ignition is on, and I'll try that right now and post back what happens.
It doesn't flash at all, it stays lit.
Anddd I reaaaallly need a car so thanks for the help and all the help in advance.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
Lmancha96
Sep 25, 2015 08:11 PM
