Power died while driving
Old Jan 6, 2009 | 04:47 PM
1988WS6's Avatar
Car: 1988 TA
Engine: 355 sbc
Just put in a new 650 amp battery two days ago and last night it died while I was driving home from work. Jumped it, drove a mile and it died again. Jumped it, drove another mile or so and it died again. Jumped it a third time, got it into the driveway and was able to shut it off.
Went into the auto parts store and had them test the alternator, it passed on all checks, but it turns out the battery is a 63 amp battery out of a 72 Monte Carlo. Now, I got some new battery cables and a ground cable and I'm hoping if I swap those out I'll start getting some power from the alternator again.
Thoughts? Help?
Old Jan 6, 2009 | 05:52 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Power died while driving
When the car is runnung the power is coming from the alternator and also keeping the battery charged at the same time. When your car is shutting down is because you drained the battery of its power and the alternator is NOT working. I think your problem is the Alternator on its last legs even if it checked ok..
Old Jan 6, 2009 | 05:56 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
I concur!
Also check the new alt when you buy it, have it tested.
Bought 1 from napa, installed it, didnt work, did this 3 times till i got one that finally worked!
Old Jan 7, 2009 | 03:37 PM
1988WS6's Avatar
Car: 1988 TA
Engine: 355 sbc
Well they tested it..I saw in the store that all of the ratings were right where they needed to be so how does that make sense that the alternator is going out?
Old Jan 7, 2009 | 03:50 PM
blkfirebird91's Avatar
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
yeah it happened to me it was the battery then kept doing the same problem and it was my vats if you have vats i suggest you check it.
Old Jan 7, 2009 | 04:15 PM
DJP87Z28's Avatar
If it is 1988 model it did not have the VAT system.
Now back to the Alternator problem, It did check OK at the store. Well the only advice I can give you now is I hope you have AAA, because that alternator will be going out.
So you can wait on the side of the road until they come and get you. Been there and had it happen, It would charge fro a while until it went completely.
Old Jan 7, 2009 | 09:47 PM
1988WS6's Avatar
Car: 1988 TA
Engine: 355 sbc
So what you are all telling me is: just get a new alternator from the actual year of my car?
Old Jan 8, 2009 | 05:06 AM
DJP87Z28's Avatar
Yes, 105 amp one would be best.
Old Jan 11, 2009 | 08:50 PM
TA-Rocks's Avatar
Car: 87 GTA, 99 VFR800
Engine: 5.7 TPI wrong heads , 781cc
Axle/Gears: 3.08, msg me if u hav 3.42 4 sale
You guys never mentioned one thing: THE wires in the car need to be thoroughly checked out. It could be that the power isnt provided because he has a bad ground. I had gone through some problems "assuming" the wiring is good in a car. The grounds can and do rust out raising resistance and blocking needed power. Just thought it might help.
Vintageracer
Jan 10, 2020 05:33 PM
jklein337
Sep 19, 2018 06:23 PM
Andrew6.688
Dec 13, 2015 10:59 AM
Wade787b
Sep 29, 2015 01:15 PM
