need fuse box area pic
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: need fuse box area pic
What year is the car ?? an 88 ?
The white box with the hose on it is for Cruise Control and should get mounted to one of the holes in the brake pedal bracket.
The wires that have plastic "caps" on them are for an aftermarket remote start or car alarm.
The Black wire with the wierd looking metal "end" ( near the gas pedal ) is for Cruise control from the steering column to the cruise control harness
I "THINK" the black plug with BLUE/PINK/BLUE wires is the dash harness connection for power door locks (I could be wrong) It would be empty if you don't have power locks.
its an 87 T/A so the wires with tthe caps i dont need to worry about thanks. also on the white connector with the spring thanks i dont have power locks but do have power windows.
Ghettobird52
Jul 5, 2024 11:18 PM
Dialed_In
Aug 20, 2015 01:45 PM
Street Lethal
Aug 13, 2015 08:28 PM
