speedo not working
Old Jan 18, 2009 | 05:26 PM
1992camaroguy's Avatar
Car: 1992 CAMARO RS
Engine: 305 AUTOMATIC V8
speedo not working
tried everything that I can think of which was change the trans sensor, swapped the speedo cluster,the ECM and buffer and still no luck (speedo tops out when only going about 15mph then it goes to 0 then stays untill you slow to a stop then it will do the same when you speed back up)
Any suggestions
Old Jan 18, 2009 | 05:40 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: speedo not working
Originally Posted by 1992camaroguy
tried everything that I can think of which was change the trans sensor, swapped the speedo cluster,the ECM and buffer and still no luck. Any suggestions
Welcome to TGO. Perhaps the drive gear is toast.
JamesC
Old Jan 18, 2009 | 08:52 PM
Car: 1992 CAMARO RS
the gear looked fine
Old Jan 19, 2009 | 06:26 AM
JamesC's Avatar
So both the drive and driven gears were good?
JamesC
Old Jan 19, 2009 | 08:24 AM
Car: 1992 CAMARO RS
they both looked good, they didnt seem to need to be replaced
Old Jan 19, 2009 | 08:52 AM
JamesC's Avatar
Well, if all the parts are correct (and working as they should) and hooked up correctly, the speedo should work. Do the other gauges function as designed? Sorry I can't offer more than that. A search might provide some info/clues that would be more helpful.
JamesC
Old Jan 19, 2009 | 09:01 AM
Chezoom's Avatar
Car: 91 RS Vert, 87 SC T-Top
Engine: LO3, LG4
Transmission: 700r4's
Axle/Gears: 2.73, not sure yet
cable stretched?
Old Jan 19, 2009 | 09:07 AM
JamesC's Avatar
90-92 would be electric.
JamesC
Old Jan 19, 2009 | 10:23 AM
groundrat's Avatar
Car: 91Z28
Transmission: WC T-5
Axle/Gears: 10 Bolt Posi, 3.08
You may need to trace the speedo wire and check for shorts. The signal may be getting shorted to ground or there is high resistance. Are the parts you swapped new or known good? Is there someone you know with a similar year that you can trouble shoot with?
Old Jan 19, 2009 | 11:36 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Connect an OBD1 scanner to the ALDL.
Drive.
See if the scanner reports speed properly.
If it does your VSS, buffer, and ECM are functioning properly.
Now with a signal generator apply 60CPS to terminal 3 on the dash PCB.
A good speedo will read 54MPH.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Old Jan 19, 2009 | 03:30 PM
Car: 1992 CAMARO RS
well all the parts that we swapped came out of a 91 rs and know to work in it
Old Jan 22, 2009 | 09:56 PM
91305rscamaro's Avatar
i have a 91 rs with basically the same problem. i have been messing with this all night mine will randomly wotrk and then it won't. mos 0f the time it is on flat 0 or whatever. mine has a short I found that out because i pulled out the senser in the tranny (the one with 1 bolt holding it in and has two wires coming out my wires are purple and yellow) i clened it up and unplugged the wires and stuff fom the tranny. ( when you pull this piece out tranny fluid will come out if tilted in any way so try to do it flat on a lift.) and then just reconnected it cause i couldnt figure the problem but then i drove my car and it worked. then i shut off the car told everyone it worked and started he car again and it didnt work. so i found out there was a short from some of the wires somewhere connected to that. So that could be your poroblem too or it could be that sensr i ws talking abou but i'd say its not worth wasting 100 dollars on and not worth going to mechanic and wasting even more money so check the wires and look for the short my suggestion would be to just get all new wires for that piece then see whats going on and after that then mayb buy the piece if it still doesnt work. I just wish someone could send me a diagram of how the wires are set up behind the dash and gauges before i rip out my wires. so if anyone can give me a sit or send me a diagram of how the wires touch the speedo that would b great. thanks for the help and hope that helped you
Old Feb 22, 2009 | 07:43 PM
Car: 1992 CAMARO RS
figured out that we needed another gear that fits onto the sensor now just trying to find the right one
Old Feb 27, 2009 | 12:14 PM
yeah, the only problem is which gear to get with howe many of these transmissions they made... That what I'm leaning towards to now is a new gear that fits right, I just got one from the dealer and put it in and now my speed ometer only works when i let off the gas. when i press the gas it hits zero when i let off it tends to work some what accuratley. such a pain..
Old Feb 27, 2009 | 11:22 PM
DyingYoung138's Avatar
Car: '86 Trans Am
Engine: 305 H.O.
My speedometer just doesn't work at all... It never budges. Stays on 0 and I have no idea why.
Old Mar 3, 2009 | 01:57 PM
yeah mine did that before i changed the gears. out of curiousity [if yours ias a electric and not a cable (1991+ is electric in the camaro)], have you taken out the speed sensor and disattached the wire and then plugged it all back in and put it all back toge6ther after cleaning in up a bit cause i did that with the gear that was in and my car and then it would work no matter how far i drove as long as the car didn't get shut off. so my suggestion is do that see what happens. cause yeah thats what mine did but only for that one ride right after i took it out and apart ands put it back together and then started the car. and then we kinda decided that it was the gears now i got a gear with more teeth, same size of course, and now it tends to work once the car has been warmed up so basically driving 4 miles straight gets it to work half decently so now i might go up one more size. cause mine works now just not to the extent i want.
Old Mar 3, 2009 | 02:03 PM
JamesC's Avatar
As I mention above, 90+.
JamesC
Old Mar 3, 2009 | 02:43 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Not to offend but, not sure you've told the "whole story". Sounds like your piecing parts from one vehicle or another trying to get it to all work?
If the car your working on came with the 700r4 that's in the car now, call the GM parts dealer with the VIN number. They can give you the correct VSS vehicle speed sensor number and correct driven gear (tooth count/color) that works with the drive gear inside the trans tail housing. Make sure you check the color of that also. Otherwise, it's a dog gone crap shoot.
Old Mar 4, 2009 | 03:14 PM
my car might have a different speed sensor not sure i got the ca a few years back but i know many camaros that didnt hve working speedos and they did make 8 gears for the 700r4 or whatever i called the chevy dealer and asked thats how i kne that but it sounds peicy cause i keep addingh on different parts to my story cause i keep trying different stuf.
Jorlain
Aug 24, 2022 05:11 PM
Jeremys87
Jul 14, 2022 09:08 PM
Wade787b
Sep 29, 2015 01:15 PM
Irocohio
Aug 12, 2015 08:03 AM
beachrodder
Aug 7, 2015 04:27 PM
