POWER LOCKS
Old Jan 20, 2009 | 07:33 PM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
POWER LOCKS
I HAVE AN 87 IROC CAMARO AND I NEEDED HELP......MY POWER WINDOWS WORK FINE......BUT ONLY SOME TIMES MY POWER LOCKS WORK....JUST RECENTLY THEY STOPPED WORKING COMPLETELY ANY HELP WOULD BE GREAT THANKS
Old Jan 21, 2009 | 01:06 AM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
Re: POWER LOCKS
id start by checking the fuse for it. also in what car and year?
do the locks try to work? or when u press the button does just nothing happen?
Old Jan 21, 2009 | 07:08 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: POWER LOCKS
If that's the case, clean with WD-40, then lube with white grease--do the same with the window tracks. While you're in the door panel, you might consider some ideas from the following link:
https://www.thirdgen.org/forums/body...servation.html
JamesC
Old Jan 21, 2009 | 10:42 AM
Engine: 350 tpi
Re: POWER LOCKS
JamesC
ITS A 1987 CAMARO Z28 AND THEY START TO WORK WHEN LIKE MY GAUGES STOP WORKING SO I THINKNITS ELECTRICAL..
Old Jan 21, 2009 | 10:45 AM
JamesC's Avatar
Re: POWER LOCKS
Huh?
JamesC
Old Jan 21, 2009 | 11:27 AM
Engine: 350 tpi
Re: POWER LOCKS
Huh?
JamesC
LIKE AFTER I HAVE BEEN DRIVING IT FOR AWHILE ALL MY GAUGES STOP WORKING LIKE THE RPMS AND ALL OF THAT STUFF AND THATS WHEN THEY START TO WORK ITS WEIRD AND I CHECKED THE FUSE AND ITS FINE SO I DUNNO WHAT ELSE TO CHECK....
Old Jan 21, 2009 | 01:15 PM
Re: POWER LOCKS
JamesC
i figured youd chime in jamesc, your the guru when it comes to this kinda stuff.
but iroc, i think u should make sure your gauge cluster is backed all the way into the switches it plugs into, also maybe even take out the cluster to see if the locks work.
Old Jan 21, 2009 | 01:21 PM
Engine: 350 tpi
Re: POWER LOCKS
HMM....WILL DO......ILL GET BACK TO YOU SEE WHAT HAPPENS THANKS
Old Jan 21, 2009 | 04:14 PM
50bmgshooter's Avatar
Re: POWER LOCKS
also turn of the CAPS LOCK
BRoss99
Aug 10, 2025 05:08 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
mantaguy
Sep 1, 2015 08:39 PM
sailtexas186548
Aug 24, 2015 10:11 PM
zayne0
Aug 24, 2015 07:22 PM
