Headlight switch or headlight motor problem?
Old Jan 24, 2009 | 12:26 PM
1 Quick T/A's Avatar
Car: 92 Firebird
Axle/Gears: 3:42
Just startd happening..
My 92 Firebird has the typical parking light/headlight switch on the dash. Well, when working normally, if you push the 'parking light' part of the switch, only the parking lights come on. But now when I push the same button, the parking lights DO come on, and the headlights will come up, but are not illuminated. The headights will illuminate when I push the headlight part of the switch. But why are the headlamp motors engaging when I only want the parking lights on? Thanks for any help..
Old Jan 25, 2009 | 12:51 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Headlight switch or headlight motor problem?
The problem is with the hard gel inserts (aka bushings) inside the headlight actuator assembly. Replace them with my 209280 deluxe headlight repair kit and I guarantee the problem will be solved.
Lon Salgren
Top-Down Solutions
http://www.top-downsolutions.com/pro...products_id=87
Old Jan 26, 2009 | 09:20 AM
Stephen's Avatar
Car: 87 GTA
Wow....With a single post of the problem a retailer has the fix to SELL him.
I'd be more suspicious of the dash switch or the control box on the firewall being faulty & short circuiting inside. I had the same problem.....I swapped out the control box (since I had a good, known spare) & that fixed mine.
Old Jan 26, 2009 | 10:27 AM
lonsal's Avatar
I'm sorry you don't believe me. Look under the customer reviews for the 209280 deluxe headlight repair kit. At least two customers posted a review and mentioned that the kit not only solved usual headlight problem of the motors continuing to run without raising or lowering, but also solved their problem of the headlight buckets rising if they turned on their parking lights:
http://www.top-downsolutions.com/pro...&reviews_id=43
http://www.top-downsolutions.com/pro...&reviews_id=79
Lon Salgren
Old Jan 26, 2009 | 01:56 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
I never put any weight on customer reviews. How does one know what's real and what's been posted by the staff? And even then, not all customers are the brightest cookies in the crowd.
Anyway, electrically and logically (going by this diagram: http://www.austinthirdgen.org/mkport...dy_wiring.gif), it sounds like the headlight module might have an internal short.
Lou
Old Jan 27, 2009 | 06:05 AM
Car: 92 Firebird
Axle/Gears: 3:42
thanks for the reply's. I should say when the buckets go up and down, there is a ' humming ' sound for several seconds afterwards. I have never had a problem with the lights/buckets before this. I was just trying to get an idea before tearing everything apart.
By the way, Stephen, You have a really slick looking GTA.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
The_Phoenix
Feb 4, 2016 07:10 AM
tnrednneck
Aug 13, 2015 08:57 AM
