87 Rear hatch light doesn't work.
Old Jan 26, 2009 | 09:52 AM
87_Injected's Avatar
Car: 2010 2LT RS
my 87 IROC rear hatch light doesn't work. I checked the bulb.. and the bulb looks fine. I replaced anyways and still the same problem. So I took apart the plastic in the rear hatch to check the wiring. I noticed there is a switch. I don't remember having this in my 92 RS I used to own. Is this the on/off switch? It seems loose where the slider just moves back and forth freely with no tension or click. Also what is this connector piece I see in the pic. I cannot figure out where it goes.
Old Jan 26, 2009 | 11:19 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: 87 Rear hatch light doesn't work.
Have you tested for battery? Same for ground?
Sorry, cannot view your pics.
Old Jan 26, 2009 | 11:59 AM
Car: 2010 2LT RS
My pics seem to be loading up fine on the forum when I view it. Perhaps something is wrong with your browser?
Old Jan 26, 2009 | 01:13 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
My 87 has the switch,
If the slider moves back and forth like that, if you replace
the switch will probably work.
Test the incoming line for voltage.
Don't know about the connector.
Later
Old Jan 26, 2009 | 01:54 PM
Car: 2010 2LT RS
Later
Where could I find a switch like this?
Old Jan 26, 2009 | 02:13 PM
jaykar's Avatar
Might try Chevy but being that old don't think they
would carry it anymore.
Best bet would be Radio Shack and find something similar.
Or even a toggle back there.
HTH
Later
Old Jan 26, 2009 | 03:58 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
I've seen lots of third gens in junk yards with that switch, im sure you'll find one there.
Old Jan 26, 2009 | 09:59 PM
Car: 2010 2LT RS
I will look into that. Hopefully that will solve my problem as the other forum member has stated.
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
NBrehm
Aug 5, 2015 08:19 PM
