MSD 6AL or MSD 6A
Old Feb 17, 2009 | 12:19 AM
AKATDOG's Avatar
Car: 84 Z28
MSD 6AL or MSD 6A
im looking to buy one of these for my camaro, im wondering if the 6AL is worth the extra money ?
Old Feb 17, 2009 | 01:14 AM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Re: MSD 6AL or MSD 6A
For stock or mild engine there is really no benifit or reason from it for the price.I did buy a MSD digital 6 when I was an extreme newbie.It may help a little but no noticeable gains or anything you can feel.Main reason I bought it was for the rev limiter and I plan on spraying it one day once I get my prom dialed in and can eliminate all knock I`m getting.It will not hurt anything but the money could be better spent on something else that would improve performance right away.
Old Feb 17, 2009 | 04:53 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
AKA if you have a stick buy a 6al for the rev limiter this way if your playin around or go to the track and you miss a shift or the driveshaft breaks you just hit the limiter and not over rev your motor cheap insurance
Old Feb 17, 2009 | 02:04 PM
AKATDOG's Avatar
Car: 84 Z28
thanks alot
Old Feb 17, 2009 | 03:00 PM
tom86iroc's Avatar
Car: 1986 iroc
anytime
Old Feb 17, 2009 | 05:22 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
The digital 6 has 2 rev limits and a retard for nitrous plus 135 mj of spark over the 6als 115 mj and only 1 rev limit, Plus you need specific chips to control the rev limits on the 6al and you have dials on the digi 6. If you got the 6al cheap then go for it but if your going to lay out 150 or more, just get that 6520 it has a lot for the $
Old Feb 17, 2009 | 08:08 PM
AKATDOG's Avatar
Car: 84 Z28
well i know someone that has the 6AL for $125 used, do these have long life periods or should i get one brand new for 200 ? or would you still say the digital 6 is the way to go ? also does the MSD 8252 Blaster HVC work with all the msd ignition controls and is it worth getting ?
Old Feb 18, 2009 | 05:54 AM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
The digital Summit digital box is better and cheaper. use to install several MSD boxes on Rx7's and finally tried the summit boxes and they actually worked out better overall.
Old Feb 18, 2009 | 09:41 AM
AKATDOG's Avatar
Car: 84 Z28
really ? anyone else have any experience with the summit digital boxes ? and is the MSD 8252 Blaster HVC worth buying ?
Old Feb 18, 2009 | 05:10 PM
The summit box is a mallory, check here for some reviews, some good some bad. The 6al is a good box but like anything electronic it has limits, so..arch it out, drop voltage to it etc,etc it will die. Use a capacitor and you won`t have troubles, it protects it from spikes and what not.
I would just go with a blaster 2 or 3 it will be fine and is alot cheaper.
Old Feb 18, 2009 | 10:16 PM
AKATDOG's Avatar
Car: 84 Z28
ok, right now i have a cheap aftermarket distributor, with a accel hei super coil, the type that sits on top of the distributor, does the blaster add on to the system or does it eliminate the super coil ?
msd blaster 2 and 3 seem very similar, is there a difference ?
also my car is automatic so should i go with a base 6A, or still go for the digital 6 ? and when u say capacitor where can i get this ? sorry for all the questions
Old Feb 20, 2009 | 02:12 PM
AKATDOG's Avatar
Car: 84 Z28
if my car is automatic is there any reason to get the 6al over the 6a ?
Old Feb 20, 2009 | 05:21 PM
The 6al has a rev limiter it`s worth while if you have some good HP I`d say 400 or more. If you already have a decent coil, stick with that. The Digital 6 box is a good deal for what it offers, I always try to buy ahead and above for the future, since I upgrade things all the time, it`s nice to buy something and actually use it for more than a year or two.
Fanatic1074
Oct 3, 2022 05:57 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
RedLeader289
May 28, 2019 01:47 PM
meeklay812
Oct 1, 2015 03:46 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
