Anything look abnormal?
Old Feb 17, 2009 | 07:34 PM
evans87's Avatar
Car: 1987 Iroc Convertible
Engine: Bone Stock, 66,000
Transmission: 5 speed
Working to find what is killing my battery and going nuts! I snapped a few pics of the area near my fuse panel. Anyone see anything abnormal? I am a little interested in the odd splicing shown in pic #3. there is a white wire with a red stripe on both sides of a green wire which is spliced in the middle? looks a little rigged to me? What does the white/red wire control? Is that a factory splice? Should I eliminate the green wire and simply join the white/red wire leaving only 1 splice, or just leave well enough alone?
Attached Thumbnails Anything look abnormal?-fuse-wiring-1.jpg   Anything look abnormal?-fuse-wiring-2.jpg   Anything look abnormal?-odd-splice.jpg
Old Feb 17, 2009 | 07:45 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Re: Anything look abnormal?
Looks like in pic 1 the red /white turns into yellow at the next splice. It does seem a little unnecessary but if the connections are good it shouldn't be a problem.
To help narrow down your draw on the battery, disconnect the + side of the battery and hook up a 12 volt light bulb between the battery and the battery cable. If there is a draw with the key off the light will be on. There is current going thru the system. Start pulling fuses one at a time until the light goes out. When you find the fuse that makes the light go out it will show you the circuit that is drawing down your battery.
db057
Sep 4, 2015 07:57 AM
midge54
Aug 29, 2015 09:51 PM
Ninetails
Mar 14, 2004 01:08 AM
1991tealRSt-topGuy
Apr 28, 2003 06:57 PM
GregN
Mar 1, 2003 07:59 PM
