dual connector Coil wiring
Old Feb 20, 2009 | 04:29 PM
trees's Avatar
Car: 87 K5 Blazer
Engine: 350 tpi
Doing a 350 tpi swap. The wiring harness that came with the motor did not have a connector for the coil so i have to figure out where the wires from the grey connector on the gm dual connector coil go.
From my stock wiring harness the large pink wire attached to the connector leads to my fuse block and has 12v when the key is turned on, the smaller wire (white) lights up when i put the test light to ground. I am not 100% sure where this white wire goes. The black connector leads to the distributor and i'm not worried about that one.
Don't hate me for this but the engine is going into an 87 chevy k5 blazer which was previously tbi.
Old Feb 20, 2009 | 05:21 PM
trees's Avatar
Car: 87 K5 Blazer
Engine: 350 tpi
Re: dual connector Coil wiring
Chevy power site said the white wire on the gray connector can be wired to a tach.
Problem i'm experiencing is that I can't get spark.
Old Feb 22, 2009 | 10:10 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Yes, the white wire goes to the tachometer in your dash.
If you don't have spark, I'd disconnect the timing set connector (I believe tan/black wire) first. If you still don't have a spark, I'd check the distributor ignition module for power.
Hope this helps.
Lou
eightsixseven
Dec 16, 2024 01:50 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Dialed_In
Aug 20, 2015 01:45 PM
