Transmission selector switch or what??
Old Mar 4, 2009 | 09:47 PM
Gilaad's Avatar
Car: 1992 Z28 G92
Engine: 350-245 (B2L)
Transmission: ?
Axle/Gears: G80
My 92 RS (V6) has a transmission gear selector button that will actuate without the key in the cylinder lock. I know its not supposed to move at all or shift while the key is out of the cylinder. So where is the problem at?? At the steering column (i can hear noise at the steering column) or beneath the shifter console (bad switch). Help is appreciated.
Old Mar 4, 2009 | 11:59 PM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
Re: Transmission selector switch or what??
There is a cable that runs from the shifter to under the column, there is a switch there that is supposed to lock the cable and thus, lock the shifter, unless the key is turned on. i'd start by checking if it's hooked up at the shifter and column, if not that then maybe a bad switch. my 91 vert does the same thing, i never bothered to look at it because it doesn't matter if it works or not to me.
jhawkeye
May 25, 2022 06:33 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
SavingPvtEric
Aug 24, 2015 08:39 AM
Dialed_In
Aug 20, 2015 01:45 PM
