Error Code 24 on a 87 IROC TPI T-5
Old Mar 6, 2009 | 08:19 AM
Pingu 2.0's Avatar
Car: 1987 IROCZ
Engine: 5.0L TPI
Axle/Gears: BW 3.45
As I began driving home yesterday I noticed my spedometer was not working and the check engine came on. I checked it and a error code 24 came up. I'm not sure where to start looking, from other threads it looks like it might be a vss problem? I'm not sure, please send me in the right direction!
Old Mar 6, 2009 | 08:46 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Error Code 24 on a 87 IROC TPI T-5
Since your 87 is cable driven, I suggest that the fault lies with the cable or speedo head. If either of those is bad, the VSS can't function and will throw a code 24, IIRC.
JamesC
Old Mar 6, 2009 | 09:04 AM
Pingu 2.0's Avatar
Car: 1987 IROCZ
Engine: 5.0L TPI
Axle/Gears: BW 3.45
also, the trip has been dead for a while and odo was reading extremely high this past weekend, if that narrows it down any...
Old Mar 6, 2009 | 09:17 AM
JamesC's Avatar
Here's a fix for the trip:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
Sounds like the speedo head, but you'd be remiss not to also check the cable. At any rate, if the speedo isn't working, there are only three possibilities: drive/driven gears have broken, the cable itself has severed, or the speedo head is bad.
JamesC
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
Out-Cast
Aug 17, 2015 10:57 AM
Sanjay
Aug 12, 2015 03:41 PM
mustangman65_79
Aug 11, 2015 03:17 PM
